Old 07-30-2015, 08:40 AM   #1
fishlurcher
Drives: Toyota Yaris 2003 1.0 vvti
Yeah first thing you do is get the gearbox warm (like before its winter) and drain that oil into a clean pan so you can examine it.
If you find a lot of metal in it (the oil has a metallic sheen) you've got a lunched tranny.
Or if no oil comes out, ditto...
If the oil looks OK put new oil in and see if you got the rattles.
Also, get the car up on ramps and go over the underside of the car looking for loose nuts and bolts. You just might find something...
Good luck and tell us what happens!
Thanks guys about to get to it been a bit busy, will first check oil level and condition, Not got good feeling but we will see 😕 let you know 👍
fishlurcher is offline   Reply With Quote
2nd, 4th & Reverse Gear Not Engaging mesci DIY / Maintenance / Service 3 03-17-2023 07:03 AM
Experimenting with bypassing the AT 4th gear prohibition when cold CTScott Performance Modifications 28 03-22-2015 08:16 AM
2nd Gen owner's impressions: 3 days with a 3rd Gen (2013 5-door LE 18k miles) nookandcrannycar General Yaris / Vitz Discussion 7 02-22-2014 08:16 PM
No 4th gear in A/T? caineroad General Yaris / Vitz Discussion 13 09-11-2009 06:47 PM
Yaris seems to get stuck in 3rd gear when going uphill 47_MasoN_47 General Yaris / Vitz Discussion 16 08-24-2009 12:22 PM
