Old 08-04-2015, 06:05 PM   #1
Rigaud
Drives: 2009 Yaris
Originally Posted by miami View Post
Thanks for the suggestion, but I am not looking for power gains so will probably pass on the TB.
What I am really looking for is less lag from accelerator input to throttle response.
The sprint booster looks good, but it is almost three times as expensive as the cheaper throttle controllers on eBay.
Correct me if I am wrong, but isn't the sprint booster essentially a "single stage" throttle controller? Or does it have other advantages over the eBay throttle controllers I listed above?
What is it exactly your looking for? Remove the response lag we have with pedal to throttle? Then the sprint booster works and has three settings. Sport setting makes a huge difference. I tried it on two Audi's and it's a totally different feeling in a good way. Yes it's expensive but remember, you pay for what you get. Cheap stuff you found on ebay is not worth it. I have a 1ZZ TB now for the past year and yes it's more alive but not like I like it or want.
For my Audi A4 Avant, a Unitronic tune helps the throttle issue but I might try a sprint booster as well.
Old 08-04-2015, 06:21 PM   #2
miami
Drives: 2007 Yaris LB Base
Originally Posted by RagnaCaT View Post
Did you Try the 1ZZ Throttle swap? I bet you will love that after it's finely tuned it does a great Job, I followed the same foot steps after my 2ZR swap and dropped in a Tacoma Throttle
Thanks for the feedback. I used to have an R53 Mini Cooper S and used the Spec D throttle controller - it worked very well. For the MINI, the sprint booster only had one setting. I was not aware it had three for the Yaris. Good to know and I'll take it into consideration!
So the 1ZZ - would you recommend it? Did it improve throttle response?
miami is offline   Reply With Quote
Old 08-04-2015, 06:32 PM   #3
Rigaud
Drives: 2009 Yaris
Yes the throttle response is way better and torque in 5th on highway plus on uphills is much improved. However the intake manifold opening is still smaller so you don't get the full benefit. I'll moding an older 1ZZ intake manifold by this weekend. None of my cars are kept normal. lol I'll go read up on the spec D throttle controler, don't know enough about it.
Weapon R throttle controller question Captain Slow Performance Modifications 1 02-15-2013 09:32 PM
3 Drive Throttle Contoller by NTD Sabretooth Performance Modifications 31 10-07-2010 12:12 PM
F/S iCocept AT-Power Throttle Controller 1NZYaris1 Items for Sale by private party 5 06-15-2010 07:48 PM
Group Buy for NTD 3Drive throttle controller twpanson Sponsors Classifieds Area 35 11-17-2009 10:18 PM
Blitz throttle controller 808_Yaris Performance Modifications 43 10-22-2009 04:36 AM
