Old 08-08-2015, 08:04 AM   #1
Originally Posted by chocolatekay View Post
Thank you all for your replies.
It turns out there is an issue with the wiring for the rear fog lamp, the bulbs and fuses have been checked and changed.
I have I booked in at my local garage to further investigate, but am worried that I will have a huge repair bill awaiting me!
My car has a towbar installed - could this be part of the problem as ive seen a few posts mention towbars and wiring.....
Feeling a bit desperate now. Was hoping it would be a straight forward bulbnor fuse change. :(
Regards,
Kay
It may be as simple as the RRFOG fuse being bad (in the under dash fuse panel) or the REAR FOG RELAY being bad (at the top of the under dash fuse panel).
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 09:47 AM
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 12:03 PM
