Old 09-09-2015, 07:33 AM   #7
Originally Posted by 07liftback View Post
Thanks CTScott! I'll check it out first thing in the morning. My hid kit is connected to a relay harness so it draws power directly from the battery once the lights are switched on. It very well could have been the culprit since it only uses the connection from the driver side headlight harness and not the passenger side. I've unplugged the hid kit completely and it still had no effect on the lights. I even pulled the fuse out, and yet again, nothing.
Could the leds in the tail lamp be an issue as well?
You could try swapping back the tail bulbs, but they shouldn't cause the behavior you are seeing.
Tags
corner lights, headlight switch, side markers, t-lp relay, tail lights
