#14 |
The white/black wire on the tail light and the side market the is the ground wire. You could try jumping that terminal on the connector to a solid chassis ground.
Did you per chance try swapping out the LED tails?
| Tags |
| corner lights, headlight switch, side markers, t-lp relay, tail lights |
