Old 09-10-2015, 02:26 AM   #8
07liftback
07liftback's Avatar
Drives: 07 Yaris Liftback
You could try swapping back the tail bulbs, but they shouldn't cause the behavior you are seeing.
Hmm, I tried pulling that relay but it did nothing. It's a grey one correct? Located in the tiny fuse box right under the passenger side headlight? I believe it only controls the dash lights. I tested the tail light socket on the side that's out and there are 3 prongs. The green wire seems to not be providing power but I'm getting a 12v reading from the red and the black one. Does this mean the ground is loose somewhere?
07liftback is offline   Reply With Quote
corner lights, headlight switch, side markers, t-lp relay, tail lights
