The white/black wire on the tail light and the side market the is the ground wire. You could try jumping that terminal on the connector to a solid chassis ground.
Did you per chance try swapping out the LED tails?
![]() ![]() Drives: 07 Yaris Liftback Join Date: Nov 2010
Not yet, but I'll try tonight. Yea, I was thinking of just grounding the wire and seeing if I can just fix it by wiring in a new ground point to the system. Will keep you updated. Thanks!
| Tags |
| corner lights, headlight switch, side markers, t-lp relay, tail lights |
