Old 09-19-2015, 11:32 PM   #1
bairjo
thank you for your response. I will be trying that.
bairjo is offline   Reply With Quote
Old 09-19-2015, 11:39 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
from factory threshold is set at 25 to 26 psi so if its messed with and u reset button at 30 psi it will trigger the warning light when it drops by 2 psi ..so try the reset first if that fails you may have a bet sensor that you will need a scanner to see what one is bad.
Low Fuel Warning Light NYC-SE Third Gen Yaris General Discussion 18 08-18-2014 04:53 PM
low gas light... b20vteg Third Gen Yaris General Discussion 3 12-24-2012 04:34 PM
tire pressure light won't reset nikvolkert DIY / Maintenance / Service 6 10-24-2010 03:58 AM
Low Tire Pressure Sensor DebbyM46227 General Yaris / Vitz Discussion 24 10-18-2010 10:02 AM
