![]() Drives: Xb Join Date: Oct 2015
Final drive question???
Hi I am new here and I don't even own a Yaris but looking everywhere it seems you guys/gals may have the answers I need.
I have a 2006 Scion xB Manual transmission. My 4 gear is now poping out and needs to be fixed. I drive a lot of freeways of 70-80mph about 80% of my driving. I am doing 25k miles a year. I love this car but don't like doing 4k rpm at 80mph. I read a forum where a guy swapped in an old Corolla transmissions with a higher final drive and said it was night and day better for all round driving and way better for freeway speeds. His rpm drooped 500 at 80mph. I also live in ut and drive in the snow a lot. So I want to put in an LSD at the same time I fix this problem. I had been looking at c160 with LSD for a swap. But the c160 final drive is so low even with the 6th gear being taller it's really no different then my gearing now so by doing the c50 to c160 swap I only gain more gears to say in a power band and an LSD but no lower RPM for cruzing. Is it possible to swap out the final drive in the c160 with my c50 or will that not work? If no is there a higher final drive to be had for a c160 that is not crazy expensive, like from another MT I can get at a junk yard? Is my best bet to swap out my final drive in my c50 with the Yaris FD, fix my 4th gear poping out problem and put in an LSD? If I do that what LSD will work? I am unsure if the FD Yaris is a 6 bolt or 8 bolt like mine. If it is 6 bolt that would be a weekend part correct? I am new to all this so any guidance is very welcome and sorry if this is all posted in the wrong place. Chad |
2ZR swap. DO IT! Ask how!
There's lots of info on gear ratios, FD swaps, and compatible gearboxes on the forums (lots of it posted by me) so I won't duplicate all of it here. I'd recommend just buying a Yaris C50 and swapping the internals. The diff is an 8-bolt, so you can't use the C150/C160 as a donor. I've got a Quaife in my gearbox and love it for daily driving. It's not as nice on ice/dirt as a KAAZ or OS Giken would be, but that's a tradeoff.
I think someone has a used gearbox that they've been trying to get rid of for a year or two in the for sale forum... *edit* Disregard, he doesn't want to ship it. Take a look on car-part.com for a used one near you. |
#3 | |
I likely have a nearly new Yaris 3.7 if you are interested. $50 + shipping.
#4 | |
Also can I put in an LSD in my xB? If so witch one? |
#5 | |
Quaife: QDF15E - ONLY if you have the stock differential and mating end ring.
Any other brand: do some research. =) |
#8 | |
No, the C15X/C16X are a smaller, 6-bolt diff. The C50 in the Yaris and xA/xB are an 8-bolt, but are also different from the 8-bolt xD C50 and Celica/MR2/Matrix C56/C59. |
The C160 is a 6 speed and has an 8 bolt diff. All the gears inside are actually much larger than the C150.
#10 | |
The C160 is a 6 speed as you already know. In order to have 6 gears you need a longer input and output shaft. The output shaft also carries one of the gears that turns the differential. The gear is part of the shaft. That shaft will not fit into a 5 speed transmission and is why non of the 5 speed final drives ratios will work in a 6 speed. |
#11 | |
I will try to find that thread and post a link. Again that's everyone. I am very appreciative. Chad |
If you want to lower your gearing just install an Echo transmission. Revs 2600 at 60mph
Echo transmissions are 6 bolt Sent from my iPod Touch |
This guy said if I understand correctly that all c50 FD are interchangeable with c160 but not c60.
http://bigmike.marlincrawler.com/for...php?topic=45.0 If it is not ok to post links from other forums I apologize and will delete. |
#14 | |
#15 | |
You would need to have them in your hands and try to pair them up. |
Anyone check out the link I posted and be able answer if that guy is correct or not?
Just pop in a Echo transmission in as mentioned earlier, this will drop your rpm significantly. Since you drive manual, why even need an LSD for the snow? Start in 2nd.
While an LSD will do the job preventing wheel spins, but I think you are wasting it specifically for snow. Sent from my A0001 using Tapatalk |
So I decided to get the FD from Jason and a c160 and see witch one works out the best. At least I will have options if one does not work.
| test drive - comparing automatic L to manual SE | cathycnm | New YARIS Purchase Forum | 20 | 11-20-2013 09:48 PM |
| WTB: shorter yaris final drive | speed1 | Willing to Buy by private party | 26 | 10-15-2013 11:57 PM |
| ctrl-alt-delete question & free anti-virus question | Shroomster | Off-topic / Other Cars / Everything else Discussions | 18 | 09-08-2009 03:57 AM |
| Question: alignment setting for a daily drive and track car? | Trish | Performance Modifications | 4 | 06-15-2009 12:04 PM |
| I got $50 to test drive | Cutie Pie #2 | Off-topic / Other Cars / Everything else Discussions | 6 | 02-23-2009 09:51 AM |
