Old 10-25-2015, 11:30 PM   #1
Innovative 1
Drives: 2007 Yaris HB 5spd
Power Enterprise supercharger install
Almost done installing power enterprise supercharger kit. Have had to modify a few things in the process. The supercharger bracket is built for the vitz of course. I had to fabricate a extension out of a piece of 1/4" flat steel at the bottom bolt hole that bolts through the base of the alternator. The bracket was off about an inch. With this diffence I had to run down to napa and get a 2" longer v-belt in order to get the tensioner positioned correctly. All of the plumbing provided with the kit is spot on. I'm intercooling it with a jdm intercooler kit so I am in the process of routing that. Its a tight fit but I'll make it work. Had to trim some of my crash bar (didn't have a choice) to tuck in plumbing in to clear the bumper. Also had to trim one of the pipes provided from jdm along with one of the 90 degree 2" couplers. All thats left after the plumbing gets wrapped up is wiring of the p-con sub computer. Then fill it up with premium and fire it up.
Innovative 1 is offline   Reply With Quote
Compilation of Yaris How-tos/DIYs YarisBueller DIY / Maintenance / Service 39 04-28-2018 09:47 AM
DIY: Colibri Power Window Install Taiyaki DIY / Maintenance / Service 15 04-28-2016 10:03 PM
kit to install power locks? songa DIY / Maintenance / Service 21 02-12-2015 07:31 AM
Installation of original power windows and locks in Yaris lantis DIY / Maintenance / Service 4 02-25-2012 02:38 PM
