It is pretty hard to have heat soak issues with the Blitz S/C. With a turbo the exhaust heats the intake air it compresses, because you have metal between the two gasses. With a S/C you would only see heatsoak if it gets crazy hot under the hood. Even on 100F+ days I don't see that effect.
The lagging of the S/C is more likely due to belt or S/C clutch slippage.
#2 | |
conundrum562
Drives: Toyota Yaris 2007 S Join Date: Jun 2010
Thanks bud I will have to check that out. Belt = Tighten it up? S/C Clutch Slippage = How do I check that out? As always appreciate the information.
--------------------------------------------------------------- BLITZ SC | CERAMIC 6301 BEARINGS | MICRO-IMAGE CRANK | NST PULLEYS TRD 71C THERMOSTAT | 1ZZ INJECTORS | TB SPACER | BLITZ SRI NGK PLUGS, COILS & MAF | DC HEADERS | CUSTOM 2.25" EXHAUST GTSPEC STRUT BAR, MID & 4-PT LOWER BRACES TANABE FRONT & WHITELINE REAR SWAY BARS W/ POLY BUSHINGS TBW SKID PLATE | FULLRIVER AGM BATTERY | MOBIL 1 EP + PROLUBE
| Tags |
| cooling, heat soak, intercooler, supercharger, water/meth |
| Blitz S/C + Cruise Control? | 47_MasoN_47 | Performance Modifications | 37 | 03-03-2013 07:28 PM |
| Advice on Blitz S/C | MGargano | Forced Induction Forum | 96 | 12-28-2012 05:09 AM |
| Blitz S/C a rebuilt and rebaged Toyota S/C? | Yaris0609 | Forced Induction Forum | 3 | 03-13-2010 12:21 AM |
| Upgrades for the Blitz S/C? | Sabretooth | Forced Induction Forum | 14 | 04-20-2009 01:29 AM |
| Blitz S/C on 08 Yaris | whooppee777 | Forced Induction Forum | 12 | 11-26-2008 01:45 PM |
