Old 11-23-2015, 01:08 PM   #1
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Originally Posted by JimKellyfan View Post
More specific on my warp is only when I am spirited driving it starts to after repeated use, but not everyday driving, it stays OK, but, I just have borderline run out. Too, looking closely, I do not need to even change my pads, but will soon, wife's Camry needs a tune up, and whatnot first on list.
But, you definitely cannot say you ride harder than any one of us, as you do not know how we drive.
What you call warp is pad material bedding into the rotor, that only happens when you stand on the brakes when their really hot sitting still. Like I mentioned before I've seen my rotor temps hit 700f, I didn't get the pedal vibration once. I've been to SC not a whole lot of mountains there, so not a whole lot of reasons to be riding the brakes like a $2 hooker.
2014 BSpec Divisional Champion
Old 11-23-2015, 08:25 PM   #2
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
Cool, thanks for the info.
Yeah, I try n use the gears, rather than stand on em in extreme circumstance, not as often as this thread makes it out to be.
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires
TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
JimKellyfan is offline   Reply With Quote
new brakes or some bs upsell? scene General Yaris / Vitz Discussion 23 02-12-2012 10:03 PM
general service of brakes TriumphAnt DIY / Maintenance / Service 10 08-07-2010 02:20 PM
Metal scratching from brakes alt_k1ll3r DIY / Maintenance / Service 16 02-11-2010 12:04 AM
