Old 12-13-2015, 03:55 PM   #1
tmontague
tmontague's Avatar
I'm also assuming that you don't need an inter cooler either if you are running low psi?
When people have posted in the past on Yw of their boosted cars throwing CEL' with a piggyback, what was the main issue's that were the reason for their problems? Or is it that the stock ECU just cannot deal with any level of boost? (hard to believe since the blitz s/c seems to work fine)
Old 12-13-2015, 08:29 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Yeah, below 6-7 psi, an intercooler doesn't net much improvement overall. Since you have to route back across the engine anyway, the intercooler is probably not much more work to install.
The ECU tries really hard to get back to the factory fuel map, so the trims keep getting adjusted. If you have a nice snug belt on a Blitz S/C, you can actually get the MAF to go out of range and throw a CEL. I've also seen too lean, too rich, and misfires across all 4 cylinders, but it's gotten better since I isolated a lot of the vacuum leaks.
DIY: Colibri Power Window Install Taiyaki DIY / Maintenance / Service 15 04-28-2016 09:03 PM
kit to install power locks? songa DIY / Maintenance / Service 21 02-12-2015 06:31 AM
Installation of original power windows and locks in Yaris lantis DIY / Maintenance / Service 4 02-25-2012 01:38 PM
