Old 08-19-2020, 12:04 AM   #1
anomoly40
Depot Damager
Drives: '08 Liftback
I know in the first few posts it says you need an 08-09 xD harness but I've seen PDF for 08-10 xD wiring. Ive also picked up a manual trans harness from a '10 xD.
Are these harnesses the same as the 08-09 in everyone's experiences?
2008 Yaris Liftback -
Bought in '12 with 80k
Sold in '17 with 180k
Bought back in '20 with 270k
Currently collecting parts for the 2zr swap
anomoly40 is offline   Reply With Quote
Old 08-19-2020, 07:28 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Yes, all years of the xD use the same engine harness for MT. Part# 82121-52E90.
Old 06-04-2023, 07:22 PM   #3
sh0rtlife
couple of mounts, harness and ecu acquired....
Old 06-05-2023, 01:45 AM   #4
sh0rtlife
the xd's seem to be poppin up about 1 a month local to semi local..if you want me to try and chase something down...
Old 06-05-2023, 01:19 PM   #5
tmontague
tmontague's Avatar
Has anyone seen my old yaris floating around for sale?
As much as it would suck to cannibalize that well sorted car, it has everything you need for the swap already, including a shortened Tercel front left axle to avoid the bind that some swaps get.
May be worth searching, I bet it isn't listed for much
Old 06-05-2023, 03:29 PM   #6
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
Im positive I saw it a while ago on Marketplace but its gone now.
MT engine harness seems to be the hardest thing to come by that I do not have. I would have had one but the junkyard I pulled the ECU from wouldn't let me buy just the harness as it "came with the engine", guy was an ass about it too. So I cut the ziptied key off the steering column and pocketed it when I went out to pull the ECU lol.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 07-05-2023, 07:52 AM   #7
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
https://www.facebook.com/marketplace...9826433819863/
Its back. Its getting passed around like crazy, this is the second or third time I've seen it listed and its always by a different person.
2014 NCP131 5 Speed
Old 06-06-2023, 12:55 AM   #8
sh0rtlife
LOL well if one pops up ill snag it
thankfully my yaris has no imobilizer so i dont need to muck with that crap, i got the harness, ecu and right side mount, the rest of the car was pretty trashed so i dint trust the other mounts
there was an xd a month ago manual in fact it was one of the "edition" versions...if it had been auto id have grabbed everything off it
Old 06-06-2023, 05:38 PM   #9
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Lol, I plan on doing what MCM did and just holding the original key next to the barrel or take the key apart and stick the module chip on the barrel permanently behind the column covers. All in theory of course.
2014 NCP131 5 Speed
Old 07-06-2023, 09:55 AM   #10
tmontague
tmontague's Avatar
No way, thanks for posting, I'm just glad people are still driving it, it was a great track car
Old 07-10-2023, 03:20 PM   #11
rpster
Drives: '07 Yaris Liftback
I've been eyeing all these 2zr swap threads and think my time has come: My 07 HB's auto transmission finally gave up the ghost (250k og miles, stuck in neutral/drive) and I am heavily considering this swap with my eye on a donor 09 XD that has a manual. So it'll be a double swap for me: 1NZ>2ZR & Auto>Man.
I had a couple questions that weren't quite clear from reading the thread:
1. ABS / Speed signal - Will I need to move over ABS from the XD to get the right speed signals to the ECM? The Yaris has no ABS.
2. Axles - If I'm swapping to the XD trans, I assume I can reuse the Yaris axles?
Thanks!
rpster is offline   Reply With Quote
Old 07-11-2023, 08:15 AM   #12
tmontague
tmontague's Avatar
Thanks!
To answer questions #2: technically yes, but I had binding issues on the front left axle, it turned out to be too long with the new engine. I solved this by using a '98 tercel axle which was an inch shorter but the splines all matches up.
Old 07-11-2023, 01:47 PM   #13
rpster
Looks like this is a relatively easy part to get, thanks for the insight!
I also did more research on the speedo sensor: The C50 on the XD can have a speed sensor added, meaning I wouldn't need to move over the ABS just to have a speed signal!
The only other question is if the driven gear for the speed sensor is already installed or not. I'm planning to open up the donor transmission anyways for inspections so here's to hoping it's already in place.
Old 07-10-2023, 03:31 PM   #14
Not to curb your enthusiasm for a swap but are you certain the tranny has given up. 2 months ago my other automatic car was stuck in gear. I had it towed to the shop and checked out. All that was wrong was the shift cable seized. Mechanic removed it, soaked it in a lubricant for 24hrs and reinstalled.
250k is really early for a transmission failure unless it's really been beat on and neglected.
Old 07-10-2023, 04:03 PM   #15
rpster
For sure it isn't the shift cable. I actually disconnected the shift cable from the trans and attempted shifting by hand at the trans itself. It's like it's hitting a wall when trying to shift to reverse from neutral. I also confirmed it's not the brake interlock either. Shift position switch tests fine too
Do y'all want to see another 2zr swap or not? Hahaha
unusual engine swap CoryM Performance Modifications 26 10-09-2015 12:17 AM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
engine swap djhuddy2442 Performance Modifications 6 04-11-2013 01:05 AM
Boost Gets U Laid eh? Count me In yaris2010RS Forced Induction Forum 128 02-02-2013 04:57 PM
Scion/Yaris engine swap mrrock Performance Modifications 1 03-02-2011 06:56 PM
