#397 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Finally read thru all this.
Been working on a 1nz swap into one of my tercels and it was pretty easy. So I naturally thought...whats the next evolution? Im a bit weird, I like to keep my cars the same displacement as they come, or smaller. But a 2zr in a tercel would be a monster. I might even consider one for the Yaris as I dont nearly drive the same mileage as I used to. It makes 107whp, 110wtq now. But to gain what, 20-30numbers more and keep using regular gas is looking mighty appealing over finishing my turbo build and run high octane. I would have to source a wrecked xD from copart to even consider the swap into the yaris that way I get everything i need
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#398 | |
2ZR swap. DO IT! Ask how!
#399 | |
Obsessed with 1.5L
#400 |
Depot Damager
Drives: '08 Liftback Join Date: Jul 2012
I know in the first few posts it says you need an 08-09 xD harness but I've seen PDF for 08-10 xD wiring. Ive also picked up a manual trans harness from a '10 xD.
Are these harnesses the same as the 08-09 in everyone's experiences?
2008 Yaris Liftback - Bought in '12 with 80k Sold in '17 with 180k Bought back in '20 with 270k Currently collecting parts for the 2zr swap |
#401 |
Yes, all years of the xD use the same engine harness for MT. Part# 82121-52E90.
#402 |
![]() Drives: 2007 Yaris RS 4 Door Join Date: Oct 2022
I just want to say to the OP and the contributors to this post:
Thank you! I'm a long way from the doing the swap as I am in the process of just collecting the parts. Hi from Toronto, Ontario, Canada |
#403 |
couple of mounts, harness and ecu acquired....
#404 | |
Gen 3 > Gen 2
Drives: NCP131, F-150 Join Date: Jul 2019
I hope the xD ECU plays nice with my 3rd gen.(immobilizer excepting of course).
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2013 Rav4 LE AWD Autotragic - Wife's
#405 |
the xd's seem to be poppin up about 1 a month local to semi local..if you want me to try and chase something down...
#406 |
Has anyone seen my old yaris floating around for sale?
As much as it would suck to cannibalize that well sorted car, it has everything you need for the swap already, including a shortened Tercel front left axle to avoid the bind that some swaps get. May be worth searching, I bet it isn't listed for much
#407 | |
Gen 3 > Gen 2
MT engine harness seems to be the hardest thing to come by that I do not have. I would have had one but the junkyard I pulled the ECU from wouldn't let me buy just the harness as it "came with the engine", guy was an ass about it too. So I cut the ziptied key off the steering column and pocketed it when I went out to pull the ECU lol.
#408 |
LOL well if one pops up ill snag it
thankfully my yaris has no imobilizer so i dont need to muck with that crap, i got the harness, ecu and right side mount, the rest of the car was pretty trashed so i dint trust the other mounts there was an xd a month ago manual in fact it was one of the "edition" versions...if it had been auto id have grabbed everything off it |
#409 | |
Gen 3 > Gen 2
#410 | |
Gen 3 > Gen 2
https://www.facebook.com/marketplace...9826433819863/ Its back. Its getting passed around like crazy, this is the second or third time I've seen it listed and its always by a different person.
#411 |
No way, thanks for posting, I'm just glad people are still driving it, it was a great track car
#412 |
![]() ![]() Drives: '07 Yaris Liftback Join Date: Jul 2007
I've been eyeing all these 2zr swap threads and think my time has come: My 07 HB's auto transmission finally gave up the ghost (250k og miles, stuck in neutral/drive) and I am heavily considering this swap with my eye on a donor 09 XD that has a manual. So it'll be a double swap for me: 1NZ>2ZR & Auto>Man.
I had a couple questions that weren't quite clear from reading the thread: 1. ABS / Speed signal - Will I need to move over ABS from the XD to get the right speed signals to the ECM? The Yaris has no ABS. 2. Axles - If I'm swapping to the XD trans, I assume I can reuse the Yaris axles? Thanks! |
#413 |
Not to curb your enthusiasm for a swap but are you certain the tranny has given up. 2 months ago my other automatic car was stuck in gear. I had it towed to the shop and checked out. All that was wrong was the shift cable seized. Mechanic removed it, soaked it in a lubricant for 24hrs and reinstalled.
250k is really early for a transmission failure unless it's really been beat on and neglected.
#414 |
For sure it isn't the shift cable. I actually disconnected the shift cable from the trans and attempted shifting by hand at the trans itself. It's like it's hitting a wall when trying to shift to reverse from neutral. I also confirmed it's not the brake interlock either. Shift position switch tests fine too
Do y'all want to see another 2zr swap or not? Hahaha |
| unusual engine swap | CoryM | Performance Modifications | 26 | 10-09-2015 01:17 AM |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 09:02 AM |
| engine swap | djhuddy2442 | Performance Modifications | 6 | 04-11-2013 02:05 AM |
| Boost Gets U Laid eh? Count me In | yaris2010RS | Forced Induction Forum | 128 | 02-02-2013 05:57 PM |
| Scion/Yaris engine swap | mrrock | Performance Modifications | 1 | 03-02-2011 07:56 PM |
