Old 01-15-2016, 09:14 AM   #1
Eforno
Drives: Toyota Yaris 2014 LE
I am not sure on the switch. Not enough info to tell.
So after looking through eBay for the Micturning Switch I posted, it states:
• Upper light is ON when the switch is pressed IN.
• Lower light can be wired to separate dash light circuit.
I guess it's not going to work.
Will these switches be my only option?
Eforno is offline   Reply With Quote
Old 01-15-2016, 09:36 PM   #2
No idea with those - There is no wiring diagram showing if the switch is isolated from the light. You need to find one (or contact the seller to verify) where the switch is one set of contacts and the light is isolated on another set of terminals.
Old 01-16-2016, 06:41 PM   #3
Eforno
Thanks, I think I'll just get both switches and try them out. If they don't work I'll just tap them together with some t-taps and male connectors. Doesn't seem logical to spend 46$ on an oem switch, when the fog light kit is practically the same price.
2012 Fog Light Kits TimmyTwo2 Third Gen Yaris General Discussion 4 10-06-2014 03:41 PM
2012 Fog lights FIY Absolutely Red 12 Third Gen Yaris General Discussion 1 09-17-2012 10:31 PM
2012 Yaris LB Fog Lights TimmyTwo2 Cosmetic Modifications (Exterior/Interior) 6 03-21-2012 04:54 PM
Need fog light switch and relay Jrilla DIY / Maintenance / Service 23 07-01-2011 11:12 AM
