Originally Posted by Eforno
So after looking through eBay for the Micturning Switch I posted, it states:
• Upper light is ON when the switch is pressed IN.
• Lower light can be wired to separate dash light circuit.
I guess it's not going to work.
Will these switches be my only option?
No idea with those - There is no wiring diagram showing if the switch is isolated from the light. You need to find one (or contact the seller to verify) where the switch is one set of contacts and the light is isolated on another set of terminals.
