#1 | |
![]() Drives: Toyota Yaris 2014 LE Join Date: Dec 2014
![]() How would you recommend going at the two clips in the two circles? Should I just start by pulling away the bottom and then work my way up without the use of any prying tools, or is there a method?
I think those are the easy one. The triangle ones are the really tight ones, where you may need some serious prying force to pop them.
If what I saw was correct, the triangles should consist of the same yellow tabs as the ones on the stereo and overhead trims. I'll give them a good yank and some prying tomorrow and see how it goes. (〜 ̄▽ ̄)〜
| Tags |
| lower knee panel, panel removal, trim panel removal |
| Help! Right side lower control arm removal | RUBBERDIPSTICK | DIY / Maintenance / Service | 15 | 12-27-2018 01:29 PM |
| Rear door inner panel removal. | mrpj | Third Gen Yaris General Discussion | 2 | 05-10-2014 04:13 AM |
| DIY rear Interior panel removal 09 3dr LB | bkndacn | Cosmetic Modifications (Exterior/Interior) | 10 | 03-11-2013 01:05 AM |
| Yaris 1.0L GS 2000 Driver's Door Panel Removal | milooshea | DIY / Maintenance / Service | 3 | 01-30-2011 12:20 PM |
