A pair of SPC bolts (upper and lower hole) should be good for around -4 if you have lowered your car some. Much of anything over -3 to -3.5 is excessive and doesn't do much for you unless you are in to that "look".
http://www.spcalignment.com/spc-performance
I'm guessing you've never tried two? I'm just curious if two skinny bolts would handle track-days or not. It's general considered unsafe to have two skinny bolts in there.
One SPC bolt will give -2.8° btw. I can't see needing any more than that for performance. |
#3 | |
When we first built the B-Spec cars we used two of the smallest OE crash bolts in each strut, was good for about -2, never slipped. Even with this hit, which broke the wheel, the bolts did not fail - although they did slip, so I replaced them, along with the control arm, spindle, axle, ect. ![]()
| WTB: Adjustable camber bolts and rear camber shims | Supra_Yaris | Willing to Buy by private party | 6 | 03-21-2015 06:16 PM |
| anyone currently running two sets of camber bolts? | DeathBeard | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 02-06-2013 01:37 AM |
| adjustable camber bolts? | b20vteg | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 08-22-2012 10:08 AM |
| Adjustable Camber Bolts | Kendrik | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 10-31-2011 02:29 AM |
| Are camber bolts needed after installing springs? | CtrlAltDefeat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 02-01-2009 12:19 AM |
