Old 01-26-2016, 10:40 PM   #1
CoryM
Drives: 2009 5-door, 5-speed
Originally Posted by Jason@SportsCar View Post
A pair of SPC bolts (upper and lower hole)
I'm guessing you've never tried two? I'm just curious if two skinny bolts would handle track-days or not. It's general considered unsafe to have two skinny bolts in there.
One SPC bolt will give -2.8° btw. I can't see needing any more than that for performance.
Old 01-26-2016, 11:09 PM   #2
Jason@SportsCar
I currently run a pair of SPC bolts in each strut, a single bolt will not give you -2.8... A single bolt has a range of +1.5 to -1.5 (that is from zero), it requires two to get more. I have never had them slip in normal use.
When we first built the B-Spec cars we used two of the smallest OE crash bolts in each strut, was good for about -2, never slipped.
Even with this hit, which broke the wheel, the bolts did not fail - although they did slip, so I replaced them, along with the control arm, spindle, axle, ect.
WTB: Adjustable camber bolts and rear camber shims Supra_Yaris Willing to Buy by private party 6 03-21-2015 06:16 PM
anyone currently running two sets of camber bolts? DeathBeard Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-06-2013 01:37 AM
adjustable camber bolts? b20vteg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-22-2012 10:08 AM
Adjustable Camber Bolts Kendrik Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 10-31-2011 02:29 AM
Are camber bolts needed after installing springs? CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-01-2009 12:19 AM
