Old 01-31-2016, 11:00 PM   #1
sarabjeet19
Drives: 2007 Yaris Hatchback
Originally Posted by nortonfb View Post
With the key on, not running, can you move the steering wheel?
If no, have you tried jiggling the wheel and turning the key to make sure the wheel is unlocking.
Is there any noise from the belt?
Did you use a meter to check the fuses?
Fixed everything, positive battery fuse terminal was the issue...
http://www.yarisworld.com/forums/showthread.php?t=28729
thanks CTScott for your kind feedback and suggestions.
sarabjeet19 is offline   Reply With Quote
Electrical Problems PS,A/C,RADIO,SPEEDOMETER,SIGNALS,AIR BAG LIGHT ON, ALTERNATOR toystory DIY / Maintenance / Service 43 04-17-2021 04:54 AM
Battery Warning Light - Different Twist maybe RutherfordmanX DIY / Maintenance / Service 3 06-08-2015 08:59 PM
Brake / Signal Light Issue PtahX DIY / Maintenance / Service 2 12-02-2014 08:57 PM
airbag light clockspring replacement issue maui DIY / Maintenance / Service 6 09-22-2014 09:09 PM
