Old 02-10-2016, 04:18 PM   #1
crazylegs
Drives: 2007 Yaris
so converting the yaris to e85 gas can give you some serious performance gains
crazylegs is offline   Reply With Quote
Old 02-12-2016, 10:27 PM   #2
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
i dont consider it as serious power because its barely a stage 1 set up..the car is slow as hell, 110hp stock with vvti whining through out the rpm...
now it just became a decent passenger car
Sent from my ASUS_Z00AD using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Old 02-14-2016, 11:36 AM   #3
crazylegs
Drives: 2007 Yaris
estimating 30% gains is pretty serious for these tiny engines, i'm planning on doing the flow mods including cams and only dream of getting similar gains.
Old 02-14-2016, 09:59 PM   #4
rabbito
rabbito's Avatar
JUN Cams? my dream.....my cousin have Vios(yaris sedan) with Jun Cams, full exhaust, E85 ecu tuned...car just jumps..
downside is i feel engine is idling loud or is it ticking? and very expensive.......
i got headers and center pipe done first before any other mod..yes, you do notice the gain
Old 02-14-2016, 11:36 PM   #5
1nz revolution
Drives: 1nzfe
I run custom JUN 10.5 race cams with Ferrea valves and springs. Beautiful set up.
1nz revolution is offline   Reply With Quote
Old 02-15-2016, 12:00 AM   #6
rabbito
rabbito's Avatar
yes, beautiful set up
Can the Yaris run on E85? Anybody try it? auxmike DIY / Maintenance / Service 37 04-06-2019 07:52 PM
E85 All Motor Build rabbito Performance Modifications 25 02-07-2016 11:01 AM
e85 kits chancellor6869 Performance Modifications 6 01-22-2015 09:36 AM
DAMN! Just put E85 in my car by accident... TheCutsman Fuel Economy Forum 9 08-12-2009 10:51 PM
Consumer Reports on Ethanol Driver General Yaris / Vitz Discussion 6 09-01-2006 11:21 AM
