Old 02-12-2016, 10:27 PM   #1
rabbito
rabbito's Avatar
Originally Posted by crazylegs View Post
so converting the yaris to e85 gas can give you some serious performance gains
i dont consider it as serious power because its barely a stage 1 set up..the car is slow as hell, 110hp stock with vvti whining through out the rpm...
now it just became a decent passenger car
Sent from my ASUS_Z00AD using Tapatalk
Cosmetic: Toyota red emblem
Old 02-14-2016, 11:36 AM   #2
crazylegs
Drives: 2007 Yaris
estimating 30% gains is pretty serious for these tiny engines, i'm planning on doing the flow mods including cams and only dream of getting similar gains.
crazylegs is offline   Reply With Quote
Old 02-14-2016, 09:59 PM   #3
rabbito
rabbito's Avatar
JUN Cams? my dream.....my cousin have Vios(yaris sedan) with Jun Cams, full exhaust, E85 ecu tuned...car just jumps..
downside is i feel engine is idling loud or is it ticking? and very expensive.......
i got headers and center pipe done first before any other mod..yes, you do notice the gain
Old 02-14-2016, 11:36 PM   #4
1nz revolution
Drives: 1nzfe
I run custom JUN 10.5 race cams with Ferrea valves and springs. Beautiful set up.
1nz revolution is offline   Reply With Quote
Old 02-15-2016, 12:00 AM   #5
rabbito
rabbito's Avatar
yes, beautiful set up
Can the Yaris run on E85? Anybody try it? auxmike DIY / Maintenance / Service 37 04-06-2019 07:52 PM
E85 All Motor Build rabbito Performance Modifications 25 02-07-2016 11:01 AM
e85 kits chancellor6869 Performance Modifications 6 01-22-2015 09:36 AM
DAMN! Just put E85 in my car by accident... TheCutsman Fuel Economy Forum 9 08-12-2009 10:51 PM
Consumer Reports on Ethanol Driver General Yaris / Vitz Discussion 6 09-01-2006 11:21 AM
