![]() ![]() ![]() ![]() Drives: toyota yaris yrs Join Date: Jun 2007
Nice..
Do you use the same engine mounts on the right side as the one in the Yaris? I'm guessing the driver side and underneath are the same because you're using the Yaris gearbox. Also I have a manual Yaris so i have to change the ecu and harness right? Sorry for the stupid questions. |
![]() ![]() ![]() Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR Join Date: Mar 2007
The right side engine mount is from a Scion XD. The middle rear and LH mounts are the same. For a manual, you would need the harness and ECU from a manual XD.
I ordered the RPM header and midpipe. I finally caved. LoL
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
Haha awesome, I did too!
2ZR swap. DO IT! Ask how!
I've got one on my wish list. I'm sure RPM and FastScions appreciate the surge in business!
For sure. I did some digging and found a 5% off coupon code on their facebook page. "tax"
I had to order a few random parts while I am in there doing this. A RH rad support, and lower rad tie bar. Both a little bent from when I hit a snow bank. Not to noticeable, but it will drive me bananas knowing that they are bent. Coilovers arrived. Will work on those while I wait for other parts. Gotta get some of the suspension stuff straighten out while I have it all apart before I throw the engine back in. |
Project is still moving along, just very, very slowly. I had to order a number of random parts to get going again. For some reason the junkyard had took the flexplate off, and I didn't realize there was a plate that was supposed to behind and in front of it. On backorder, or course. The RPM exhaust is gonna be another two weeks.
On the bright side, I am taking the time to attack some of the rust on random parts. |
I'm probably 6 weeks out on mine, trying to pick up smaller components along the way. I've already got the wire harness. Engine ECM, MAF and intake are next on the list.
#9 | |
![]() ![]() ![]() Drives: MR2 Spyd/Type R/Yaris/Civic Si Join Date: Feb 2007
Will |
That's the plan! =) I don't know if I'll start a thread before I have all the gubbins, because that can be a disaster if I don't get everything and have to abandon the project.
Quick pic of my front swaybar repaint. It was rusted really badly, so I just took it out and took the angle grinder to it and then primed and repainted. Gonna shoot a couple coats of clear coat, and should be good to go.
20160309_164153.jpg |
A couple quick pics. I have a lot more I am gonna organize to try and provide a more complete guide.
DSC_9490.JPG DSC_9503.JPG DSC_9506.JPG |
Data doesn't lie
Looking good!
#14 |
Speed sensor wiring
Here is my rundown of the speed sensor.
The XD harness does not have the speed sensor from the Yaris tranny. The harness plug in the fuse box has the empty spots for it. The speed sensor on the transmission DSC_9505.JPG The sensor plug: DSC_9509.JPG DSC_9510.JPG Use a pin to remove the wires, gotta kinda fiddle with it. DSC_9514.JPG The Three wires you want to remove from the yaris plug: DSC_9511.JPG DSC_9512.JPG Where they go in the XD harness plug: DSC_9516.JPG DSC_9517.JPG While you at the plug on the XD harness, remove the MAF power wire. It is the black with silver markings. MAF sensor wire.JPG |
#15 |
Ground the transmission wire
You will need to ground the torque solenoid wire to the transmission.
EDIT: UPDATED PROCESS FOR XD HARNESS. ALL YOU NEED TO DO IS ADD A PIN/WIRE TO THE EMPTY PIN LOCATION 9, NEXT TO THE BLUE WIRE IN SPOT 10, SO YOU CAN GROUND IT OUT. REALLY EASY. EDIT: NO NEED TO DO THIS PART!! Pull the loom and tape back from the transmission harness. DSC_9508.JPG EDIT: LEAVE THIS WIRE ATTACHED!!! This is the blue wire you want from the upper plug: THIS BLUE WIRE IS PIN 10. YOU NEED TO ADD A WIRE/PIN FROM YOUR OLD YARIS HARNESS TO PIN LOCATION 9, WHICH IS EMPTY ON THE XD HARNESS. THAT IS WHAT YOU WILL THEN GROUND TO THE TRANSMISSION. DSC_9507.JPG THIS IS WHAT PIN LOCATION 9 SHOULD LOOK LIKE, NOT 10. IN THE SPOT THAT THE BLACK RUBBER PLUG IS IN, NEXT TO THE BLUE WIRE. I grounded it to this point on the case. The hole was not threaded on my trans, so I used a 6MM x 1.00 tap and ran a bolt in there to ground it. DSC_9519.JPG Last edited by brushforhire; 05-03-2016 at 11:19 AM. Reason: CORRECTION |
#16 |
Flexplate Fun
I am posting this, because my junkyard thought it was easier to remove the flexplate and spacers and throw them away, instead of leaving them on. I bought a flexplate on put it on, without realizing that there were supposed to be spacers. Ugh.
The supplies: DSC_9497.JPG DSC_9498.JPG Inner spacer: DSC_9499.JPG Plate and outer spacer: DSC_9500.JPG The bolts that hold the plate on, put a drop or two of blue threadlock on each bolt. They get torqued down to 65 ft lb. |
#17 |
Data doesn't lie
Good work man!
(for those that use a corolla harness don't forget to swap the SL solenoid pin at the ecm also!)
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 03-20-2016 at 09:52 PM. |
#18 |
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 02:58 PM |
| 1nzfe throttle body swap and fitment questions | EchoBob02 | Performance Modifications | 14 | 05-01-2014 08:02 AM |
| 60/40 to Bench Seat Swap Issue | CTScott | Cosmetic Modifications (Exterior/Interior) | 24 | 11-26-2012 02:45 PM |
| FS: COMPLETE 2ZZ SWAP!!!! (SOCAL) | AdeJong 03 | Items for Sale by private party | 4 | 04-05-2010 11:25 PM |
| Gauge Cluster Swap, other interior swap questions. | Adrenalingirl_K | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 04-09-2009 03:32 AM |
