Old 02-21-2016, 07:25 PM   #1
Frank the Tank
Drives: 2007 Toyota Yaris
so what parts are you using?
does this car have abs?
Frank the Tank is offline   Reply With Quote
Old 02-21-2016, 08:17 PM   #2
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
I am using a scion Xd engine, harness, ecu, alt, a/c compressor, etc. Not totally sure what year yet. All the stuff has only 65k on it. Everything is from the same vehicle except the a/c compressor.
According to Armstrongracing's thread, the needed parts are:
1)2ZRFE engine with ALL components and accessories from a 2009+ Xd, Corolla
2)ECM from a 2008-2009 Xd applicable to your car in auto or manual trans
3)Xd engine harness also applicable to your car and transmission choice.
4)Xd RH engine mount and bracket
5)Xd exhaust midpipe
6)Xd intake AND MAF sensor
7)Xd a/c compressor lines - I did not need these. I was able to reuse my old lines.
8)Mini-add-a-circuit (for the MAF sensor, it has different wiring and needs this. Thank you for the correction Armstrongracing).
In PA they can't sell used cats without them being re-certified, which isn't worth the money. So I asked them cut off the top of the exhaust pipe, so I could use the flange and weld a new exhaust to it.
I do have ABS
Last edited by brushforhire; 04-01-2016 at 10:43 AM. Reason: Updating the parts list.
brushforhire is offline   Reply With Quote
Old 02-21-2016, 08:26 PM   #3
Frank the Tank
Will this be a manual transmission?
1nzfe throttle body swap and fitment questions EchoBob02 Performance Modifications 14 05-01-2014 08:02 AM
60/40 to Bench Seat Swap Issue CTScott Cosmetic Modifications (Exterior/Interior) 24 11-26-2012 02:45 PM
FS: COMPLETE 2ZZ SWAP!!!! (SOCAL) AdeJong 03 Items for Sale by private party 4 04-05-2010 11:25 PM
Gauge Cluster Swap, other interior swap questions. Adrenalingirl_K In Car Entertainment + Electronics (audio / video / alarm) 4 04-09-2009 03:32 AM
