#2953 |
![]() Drives: 2002 ECHO Join Date: Aug 2014
howdy. 02 Echo, sorta yaris'ish. got out of car audio when the Flood bloody ATE my Fiero as I had the Sony XES P1/X1 system out to swap doors to get Electric windows to make more room for the woofer door pods.
with the Time Alignment I was more concerned with the angles of the driver placement than the physical distance regarding soundstage. |
#2954 | |
I'm sorry for your Fiero D.
. CLA 250, 4MATIC |
#2955 |
Time for a small update:
The passenger's side Midbass and Horn are fully installed and last night I played some music through them with very conservative x-over settings, This is the first time using Horns and what can I say... running "flat" first impressions with no eq... tonality is really nice, the combo sounds very crystal clear. ![]() ![]() ![]() D.
. CLA 250, 4MATIC |
#2956 |
Link for a short video
LINK https://youtu.be/OHyK9YW5vQ8 <iframe width="560" height="315" src="https://www.youtube.com/embed/OHyK9YW5vQ8" frameborder="0" allowfullscreen></iframe> D.
. CLA 250, 4MATIC |
#2957 |
boydstir
hi looking for help on finder speaker cloth high quality finally got my pillars almost finished need special cloth for the new grills and meanwhile that i would show my stealth style pillars set in not bulging out in the way
#2958 |
That looks good, did you cut into the metal behind to fit the Mids?
I usually go to Parts Express they have 2 kinds of grill mesh, I would get the more expensive, it's very easy to work. D.
. CLA 250, 4MATIC |
#2959 |
. CLA 250, 4MATIC |
#2960 |
. CLA 250, 4MATIC |
#2961 |
. CLA 250, 4MATIC |
#2962 |
You can see how the bottom of the dash becomes part of the horn. The interior design of the CLA really helps.
![]() D.
. CLA 250, 4MATIC |
#2963 |
After installing and tuning with ID mini-horns, I got a very solid Center image in the middle of the dashboard about chin height. Sounds natural and very realistic, Impact and dynamics are awesome. I've been able to tune and recreate a better sound stage instead of using cone speakers.
I can't complain, the mini horns perform really good, and the more volume I turn on the better they sound with very little distortion... The only issue (not really but always looking for a better sound stage)... The Left side of the stage (Pilot's side) with technical tracks everything above 800 Hz reaches the sail panel bringing the stage far left, but at around 300-700 Hz it pulls in about 2-3 inches. I have a couple of ideas to minimize this issue in the near future, it's all about perfection and better sound! this is the never ending story. Brilliant design and a better way to bring the sound straight to our ears with fewer reflexions. D.
. CLA 250, 4MATIC |
#2964 |
Only Happy When it Rains
that's amazing looks stock.
Colin Chapman disciple |
#2965 |
boydstir
Very little trimming was done for the whole job
Pictures of the grills coming soon I really like how they flushed up to the a pillar
#2966 | |
D.
. CLA 250, 4MATIC |
#2967 |
Dang, I am getting all warm fuzzies following along here.
The speaker angle I was talking about is more like holding a speaker in each hand, arms held streight outin front, then spreading arms apart EQUALLY .that angle. Mount the drivers wherever the car would intersect the arm then time delay the actual distances away. I ended up with the left tweeter about 1.5 feet from, aimed directly at, my left ear, with the right mounted atop the dash. Severly goofy looking but soundstage ++ |
#2968 | |
share some pictures, would you? D.
. CLA 250, 4MATIC |
#2969 |
Roadrunner Jr.
BOO!
Looks like you've been putting some work in on the Benzo!
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#2970 |
You've been working on Deathtrap I've been working on the Benzo! D.
. CLA 250, 4MATIC |
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 01:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
