Old 03-04-2016, 04:58 PM   #1
Ryano
Drives: Toyota Yaris YR Upgrade 10
AU Cluster MT Gear indicator
Hi All,
I was reading a previous thread from 2009, where a member bought a cluster from AU to the USA, and there was mention in there from someone else about getting a part of the digital cluster to work, namely, the gear position indicator.
According the Owners Manual, the "Cruise information" only works on South African models (this shows your DTE, average speed, ambient temperature, etc). Underneath the tachometer there is this small box with a couple of letters and a multi-segment display that should be able to show what gear is engaged.
Like this
The posts stopped on that thread back in 2009, so seeing as it 7 years later, is there a way to get this to work? It doesn't really matter if it can't be done - it's just something I would like to have on the dash
Ryano is offline   Reply With Quote
Please Help no rpm indicator, gear indicator, door indicator yaristar DIY / Maintenance / Service 42 02-19-2014 11:56 PM
Headlight Indicator, Gear Lights, AC Lights All Out Hardicus DIY / Maintenance / Service 15 11-09-2013 06:50 AM
Gear Indicator Manual [Idea] TPA5 Cosmetic Modifications (Exterior/Interior) 15 06-14-2012 02:18 AM
HID Kit High-Beam Cluster Indicator Problem Split Cosmetic Modifications (Exterior/Interior) 21 07-24-2010 06:50 PM
Shift Knob with LED Gear indicator Ferret_san Cosmetic Modifications (Exterior/Interior) 8 09-30-2007 12:06 AM
