Old 06-09-2012, 10:01 AM   #1
TPA5
Wait, what?
Drives: NULL
Gear Indicator Manual [Idea]
Hey all,
So I was driving in my '12 Yaris yesterday (it's manual) and I got to thinking (Surprising, I know).
I thought it would be just the bee's knees if the Yaris has a gear indicator for the manual. Why? Because it would look kinda cool. At least; I think it would. A nice set of LED lights that simply displays "R, 1, 2, 3," etc.
I'm thinking that this is possible with micro-switches, an Arduino board, and a bread-board with LED lights. Mount the micro-switches so that when the gear is shifted, they are pressed and send a signal to the Arduino, which then displays the appropriate number/letter. If no input is detected, i.e: neutral, than 'N' is displayed.
It'd be a bit of work, but would be cool if I could pull it off.
What do you guys think?
TPA5 is offline   Reply With Quote
Old 06-09-2012, 10:31 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I've thought about it too, but I also work for a company that makes automatic shifter assemblies for almost every major car brand. I've seen what goes into something like this, and it's not trivial. The biggest issue I can see with the switches is the 'slop' in the shifter. I've installed cable bushings and an engine-bay short shift kit and there's still an awful lot of play. It has a lot to do with the linkage on the transmission and the tolerance of the joints on both ends.
One option would be to get some weatherproof switches and put them around the shaft of the shift actuator. It has a fairly limited range of travel compared to the in-cabin lever. Another option would be to find a location on the shift cables where you could use a hall-effect sensor to watch which direction they were being pulled/pushed. I think there's too much variation in the shift lever position to use switches without fabricating some brackets or bumpers.
If you're able to get something working, that would be great. You might even want to use a 14-segment LED for the indicator instead of single LEDs.
Old 06-09-2012, 10:46 AM   #3
TPA5
Wait, what?
Drives: NULL
Thanks for the input! I see what you mean by the slop in the shifter. I may have to get creative with mounting the sensors. I'm at work right now, but when I get home I'll poke around and see if I can figure something out.
What would be the benefit of using a 14-segment LED? Cosmetically nicer looking or easier to work with? I haven't really ever done any work with LED's or such before, so I'm trying to learn as I go. I also would want to try to stick it somewhere it would look like it's supposed to be, not just hanging out somewhere, so I'll have to check that as well.
Old 06-09-2012, 01:07 PM   #4
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
the 14 segment LED is kind of like the 7 segments that we are all used to (all lit up, looks like an 8) but with the 14, you can get an R out of it.
I could see simply having 6 proximity switches (one for each gear) and having a condition if none are actuated. the proximity switches can be magnetic and just go off of the metal in the shifter. you can set the sensitivity so the slop may not be an issue. that would require a bracket on the underside of the shifter and not sure how much space there is under there to do all that. I haven't taken mine apart yet. been thinking of it just to put in the metal bushing to try to get some of the slop out of mine and possibly put the "in cabin" short shifter in it as well.
it is a neat little project. I would say to mock up something and don't worry about aesthetics yet. get it working, then make it pretty. doesn't matter how pretty it is if it doesn't work (goes for women too).
Old 06-09-2012, 03:01 PM   #5
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Only CTScott can grant your Yaris wishes you desire.
Old 06-09-2012, 03:49 PM   #6
TPA5
Wait, what?
Drives: NULL
I was thinking of using this for the display: http://www.spikenzielabs.com/Catalog...roducts_id=588
And this to control: http://www.spikenzielabs.com/Catalog...roducts_id=582
And possibly this as a sensor, with credit to CrankyOldMan for the idea: http://www.spikenzielabs.com/Catalog...roducts_id=189
That matrix display already has a library written for the Arduino, which would make programming easier.
Old 06-10-2012, 09:07 PM   #7
CrankyOldMan
Interesting choice with the LED matrix. The shortfall with that is you will likely have to do some multiplexing to get the display working properly. Not a huge hurdle, but it will make the program more complicated. The advantage of a single 7-/14-/16-segment display is that each segment has its own control, and only requires multiplexing if you need more than one digit.
After pondering the Hall effect sensor on the cable, you would have to find a place where you could mount a magnet in/on the sliding portion of the cable. There are larger bar-type Hall sensors if you wanted to try and monitor the bottom of the shifter, but they run upwards of a kidney or spleen.
Old 06-10-2012, 10:49 PM   #8
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Have you seen this? http://www.youtube.com/watch?v=eWxbsopQ8I0
Old 06-11-2012, 07:02 AM   #9
CrankyOldMan
Originally Posted by 47_MasoN_47 View Post
Have you seen this?
The theory is sound and the breadboard proof of concept looks great, but the reality of getting the sensors in a location where they can consistently detect the shifter position is another matter entirely. In this case, it's not critical that the gear is known to a very accurate degree.
I'm not trying to shoot down his idea, I just want to make sure we all understand the complexity of implementing this sort of thing.
Old 06-11-2012, 09:33 AM   #10
You could also pick up engine RPM and wheel RPM signals and compare them to deduce gear ratios, no extra hardware necessary but some good logic needed!
Old 06-11-2012, 12:00 PM   #11
There's a shift knob that does that, it's really cool. I tried to start a Group Buy for it quite a while back.
poor video, but you get the idea:
http://www.youtube.com/watch?v=lKN_r2JN3HY
Old 06-11-2012, 05:53 PM   #12
CrankyOldMan
I wonder if they used an accelerometer in the knob body...
Old 06-12-2012, 10:00 PM   #13
TPA5
Wait, what?
Drives: NULL
That's pretty cool, they also have a mountable gauge for your dash. I think though I'm still going to try to tackle it myself, simply for the hobby of it all.
Sure it'll be complex, irritating, frustrating, and probably not work. But hey, if it does I'll be simply chuffed. Especially since I'd be able to do it for cheaper than the almost $200 they want for that Indy-Cator.
Old 06-13-2012, 12:54 PM   #14
Yaristeve
Drives: 3-door hatch
Interesting solution! This would be the easiest since OBDII port would already have the info (but then you would need to figure way to crack the OBDII protocol). The logic should be fairly straightforward: you would only need to calculate MPH/RPM which will stay constant for each gear regardless of speed or RPM in that particular gear (unless you are drag racing with those flabby sidewall drag slicks)...
but...
Other than the cool factor, why not just glance down at the shifter? I can understand the possible need for a gear indicator for a sequential shifter, though (I often wish my motorcycles had a gear indicator)...
Old 06-13-2012, 02:43 PM   #15
TPA5
Wait, what?
Drives: NULL
Originally Posted by Yaristeve View Post
but...
Simply for the cool factor. No other reason haha.
Old 06-14-2012, 01:18 AM   #16
Yaristeve
Oh, okay. That's what it's all about, having fun wth your car.
Experimenting with bypassing the AT 4th gear prohibition when cold CTScott Performance Modifications 28 03-22-2015 08:16 AM
Toyota C160 Reverse Gear Problem Parmas DIY / Maintenance / Service 2 12-01-2010 01:30 AM
2006 Yaris 1.3 TR, 80k miles- Clutch need pressing to its end OR Gear change getshard planet DIY / Maintenance / Service 0 08-15-2010 10:20 AM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
New Owner - Lights on Gear Shift javagirl New YARIS Purchase Forum 8 05-22-2009 02:23 AM
