#1 | |
![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
i bought a aftermarket L.E.D replacement bulb and one day i cannot use high beam..went to mechanic and toyota dealer, they said wtf?!...we checked that electricity current is flowing..when we change back to oem bulb it worked like a charm..i bought set of H4 brighter bulb and its working normally..they said some bulbs just dont work.. if this is not the problem look for 1. broken fuse inside the engine bay 2. use the machine to check the electricity current Sent from my ASUS_Z00AD using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
#2 | |
![]() Drives: Yaris hatchback 2007 Join Date: Feb 2016
Maybe the reason is the fuse. I will check it Gửi từ Redmi Note 3 của tôi bằng cách sử dụng Tapatalk |
#3 | |
| diy HID projector w/ halo headlight install | tmontague | DIY / Maintenance / Service | 17 | 02-04-2016 11:34 AM |
| Replacing headlight bulbs in under 5 minutes without removing the bumper | 07liftback | DIY / Maintenance / Service | 0 | 01-23-2015 11:11 AM |
| DIY Projector/HID (sedan) | Brian | DIY / Maintenance / Service | 145 | 02-05-2012 04:13 AM |
| How To Smoked Sedan Headlight -DIY | zulhizainL902S | DIY / Maintenance / Service | 26 | 01-14-2011 02:12 AM |
| Glassylite Headlight Restoration Kit | TEHxFALLEN V1.2 | Photo-Video-Media Gallery | 1 | 07-03-2010 12:51 AM |
