Originally Posted by rabbito
did you change the bulb...if you did i had same problem..
i bought a aftermarket L.E.D replacement bulb and one day i cannot use high beam..went to mechanic and toyota dealer, they said wtf?!...we checked that electricity current is flowing..when we change back to oem bulb it worked like a charm..i bought set of H4 brighter bulb and its working normally..they said some bulbs just dont work..
if this is not the problem look for
1. broken fuse inside the engine bay
2. use the machine to check the electricity current
Sent from my ASUS_Z00AD using Tapatalk
Thx u for the feedback. Now i use spyder after market headlight. But i have same problem with original headlight (valeo). Highbeam bulb - can work, not dead; but when u pull back for flashing - only work when headlight is on :( when knob turned to "off", u pull back for flashing highbeam - nothing happend :(
Maybe the reason is the fuse. I will check it
Gửi từ Redmi Note 3 của tôi bằng cách sử dụng Tapatalk
