#19 |
#20 |
Mr. 155 and climbing
Ouch! Where do you purchase at? NGK IFR5A11 In my experience NGK plugs are just as good or better than DENSO ![]() I can go to my local CarQuest and get them for even less than the $8+ on Amazon. The net price on them is around $4 each so even at the $8+ is one hell of a markup!
#21 |
dealer sells them at 17.50$ each.
obviously i didn't go with those. I think i paid 35$ or so for a complete set of denso on ebay. |
#22 | |
Yeah, I would have to be in a real bind to buy at the stealership with how damned unreasonably expensive they usually are. sent from my m-o-b-i-l-e
#23 |
I guess it depends on what you buy.
I always get my oil filter from the dealer (at least when i have time to pass by). they are only 6.99$ + taxes |
#24 |
I suppose that maybe I am an exception since my "local" dealership is 60 miles one way away.
#25 |
everything is far in the US. lol
There are at least 6 toyota dealers around the area within a 20mi radius here. LOL |
#26 |
![]() ![]() ![]() Drives: 2007 red Yaris HB AT Join Date: Dec 2013
Hi everyone.
I was changing oil today and decided to check sparkplugs to see how they are wearing at 70,000 miles. The plugs came too easy for so many miles. It turned out the dimwit previous owner replaced 120,000 mile OEM iridium with some aftermarket junk. Bosch Platinum +4. What is this junk? The plugs looked just like these:
#27 |
Bosch generally doesn't make junk. As for using non-iridium I haven't used iridium plugs for most of the life of my car without issue.
#28 |
#29 | |
![]() Drives: 2007 Yaris hatchback Join Date: Jan 2013
Funny you call these junk! They're the top of the line platinums. As for the pictures you just posted, my NGK's I had in 3 weeks ago did the same thing than those Bosch plugs. |
#30 | |
I knew about frequent problems with defective Bosch plugs, but, not being familiar with this weird 4-ground electrode, I looked it up. Apparently they are notorious for misfires and poor engine performance. Part of the problem is explained in this study: http://wenku.baidu.com/view/d5c9374c...fa1c7cde7.html +4 were the worst plug in that study (table 9) due to the massive +4 ground electrode quenching the flame kernel. Notice that the +2 did actually well. More is not better. Another problem is the cheap tiny 0.4 mm pure platinum electrode. Long life plugs require either 0.7 mm iridium or 1.1 mm platinum electrode (and platinum on ground electrode). 0.4 mm pure platinum has very short life, no more than 20,000-30,000 miles. Clueless +4 buyers (like the previous owner of my car) are sucked into buying this overpriced, low performance, and low life plug, keep it forever (platinum, baby) and have nothing but problems. I'm swapping them for denso platinum TT plugs this weekend. |
#31 | |
i guess u have never worked flat rate...lol that is good idea if u do it urself but honestly not many shops will ...hot or cold they come out lol Torque is ...snug plus one lol |
#32 |
#33 |
Pingolfer
Drives: 2007 Toyota Yaris 3 door hatch Join Date: Jan 2016
never regap a platinum or iridium plug ( you will render it useless ). Also NGK plugs do NOT need anti-seize, as a matter of fact, NGK say NOT to use it, the chrome threads have an anti-seize built into them. Use anti-seize on Autolite or bare steel threads plugs only
#34 |
Pingolfer
never regap a platinum or iridium plug - it will render them useless. No need to use ant-sieze on NGK plugs, they do not require it, and it is recommended by NGK tht you do not (using it is detrementral). Use never-
sieze only on plain steel threads like Autolite plugs, AC Delco |
#35 | |
the real reason not to use anti-seize is because it messes up the torque value. It's OK to use anti-seize AND decrease torque. |
#36 |
![]() Drives: 2008 yaris Join Date: Apr 2017
What does Toyota know anyway, RIGHT. 100,000. THEY KNOW WHAT THERE TALKING ABOUT.
| did autolite spark plugs screw up coil or coils ?? | la_scanner | DIY / Maintenance / Service | 20 | 04-09-2009 02:07 PM |
| Where do I buy ngk iridium tip 7 heat spark plugs? | PETERPOOP | Performance Modifications | 23 | 03-08-2009 08:34 PM |
| Upgraded Spark Plugs For Boost | whooppee777 | Forced Induction Forum | 9 | 02-14-2009 01:53 PM |
| Dual ground electrode spark plugs | Kitt | DIY / Maintenance / Service | 15 | 02-09-2009 11:08 AM |
| Spark Plugs | YamilR | DIY / Maintenance / Service | 2 | 09-28-2007 08:38 PM |
