Old 03-20-2016, 12:50 PM   #25
Pingolfer
Pingolfer
Drives: 2007 Toyota Yaris 3 door hatch
never regap a platinum or iridium plug ( you will render it useless ). Also NGK plugs do NOT need anti-seize, as a matter of fact, NGK say NOT to use it, the chrome threads have an anti-seize built into them. Use anti-seize on Autolite or bare steel threads plugs only
Pingolfer is offline   Reply With Quote
did autolite spark plugs screw up coil or coils ?? la_scanner DIY / Maintenance / Service 20 04-09-2009 02:07 PM
Where do I buy ngk iridium tip 7 heat spark plugs? PETERPOOP Performance Modifications 23 03-08-2009 08:34 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 01:53 PM
Dual ground electrode spark plugs Kitt DIY / Maintenance / Service 15 02-09-2009 11:08 AM
Spark Plugs YamilR DIY / Maintenance / Service 2 09-28-2007 08:38 PM
