Old 03-28-2016, 12:47 AM   #1
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
i have intake, full exhaust except the tip, RS parts (maf, solenoid), larger injectors, 7 heat range spark plugs with E85 timing advance tuning ecu..
suspension, change to hankook tires, front and rear sway bar, dropped 1.5 with performance replacement shocks and springs..
this car is very tiring..very hard to make car go "fast" without spending a lot of money...they have bolt on JUN Cam for NA set up but expensive as sh*t...turbo set up costs a lot too..i just drive this car for hitting corners and going to supermarket..if i have set up for B16 Honda above, i will be flying...seriously..
i guess 1zz TB & pulley will be my next set up..i dont think its going to make any difference though..lol
Sent from my ASUS_Z00AD using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Old 04-10-2016, 03:05 AM   #2
TRD SPEC
TRD SPEC's Avatar
Drives: Ncp42
Is it automatic?
TRD SPEC is offline   Reply With Quote
Old 04-10-2016, 04:47 AM   #3
rabbito
rabbito's Avatar
Originally Posted by TRD SPEC View Post
Is it automatic?
yes. funny thing is there isnt much difference with manual...the tuning group all drive 1nz with either manual or auto...when we tuned the ecu, we use L->2->3->D gears.. -_-
Old 05-02-2016, 05:29 PM   #4
longlivekel
Drives: Rover Mini S
Maybe someone can answer this.
What type of gain can you get out of a 1nzfe if you only add a piggyback or standalone?
Just curious if a retune could help squeeze any type of performance benefits from it.
longlivekel is offline   Reply With Quote
Tags
engine, improve, performance, tweak, vitz rs 1.5 2001
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
FS: Used Beatrush Engine Roll Stopper FunctionSpec Items for Sale by private party 7 06-02-2010 01:38 PM
engine swap update Adriaan Canada 5 03-03-2009 06:21 PM
Info regarding Engine change. sheraz2000 General Yaris / Vitz Discussion 5 01-08-2009 12:51 AM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 10:53 AM
