Old 03-29-2016, 09:13 PM   #1
ercdvs
Drives: 2010 Yaris
CTScott are there still no good options for fog lights off the shelf (2010 hatchback) or is everything a piece together parts list ?
ercdvs is offline   Reply With Quote
Old 03-29-2016, 09:55 PM   #2
I have not seen any good complete kits since MicroImage closed. I used to build the plug and play harnesses for them and can modify the crappy kits into the equivalent.
Old 03-29-2016, 10:20 PM   #3
ercdvs
Drives: 2010 Yaris
Was this plug n play solely for the benefit of connecting to a fog enabled stalk, or was the use of the switch in between the seats more straightforward ?
Based on the wiring diagragm and parts I was looking at, it looks to be a simpler install so long as i wire to the relay properly.
Old 03-30-2016, 06:03 AM   #4
The purpose of the plug and play kit was to take advantage of the wiring that already goes through the firewall for fog lights.
The aftermarket kits are not actually designed for the car. There was a DIY on here about using the aftermarket kits with the OEM wiring, but the internal circuitry of the switch included with the kit bridges the switching and the illumination circuits together. Also the relay included with most aftermarket kits is garbage and many who have used it have eventually had it internally fail and melt its plastic case.
Old 03-11-2019, 07:20 AM   #5
lespaulstd
Drives: Yaris
I am planning to install a cheap kit in the yaris using the original stalk and relay in the inside part of the car. However, since there is no possibility of getting the adapted harness, could you tell me which kind of pins should be used to connect both lights to pin 1 and 2 in the relay box?
lespaulstd is offline   Reply With Quote
Old 12-21-2021, 06:06 AM   #6
David90
Drives: Mazda
I actually would like to know the same...
David90 is offline   Reply With Quote
Fog Light wiring Rammy DIY / Maintenance / Service 0 11-08-2012 08:34 PM
viene viene FOG LIGHT IN Da HOUSE!!! toro yaris pr Caribbean 27 07-18-2010 04:50 PM
My Yaris Fog Light ezlove0710 DIY / Maintenance / Service 7 08-07-2009 06:15 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
