The offset is fine. I run the same tire size, but with the DF's the car will not sit low enough and you will have a big gap between the fender and the tire (almost like stock). You might consider 205/50/16 if you want the lowered look without the wheel gap.
I know right?
Thanks so much for the input guys!
I was considering 205/50/16s but I've read posts by another user (can't recall his username at the moment) running this size tire on the same size wheel with lowering springs and he said he's experienced slight rubbing. His offset is +40 I believe though. His car does look great with the setup but I'd rather not run the risk. |
#3 | |
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
#4 | |
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
almost stock? no way. we're talking 24.1 to 23.3 diameter, from a 4 inch side wall to a 3.6, ok this is less than half an inch, notable but that is not back to stock, that gap was major that would be the difference from 205/50/16 to 205/45/16 just sayin'
SPONSORED BY
| need 17inch rim guidence | chino_potato | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 46 | 04-09-2007 12:09 PM |
| Max offset | riceboy | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 05-01-2006 09:57 PM |
