Old 04-21-2007, 12:10 PM   #4
driver centric
I know right?
driver centric's Avatar
Drives: 07 Bayou LB
Thanks so much for the input guys!
Originally Posted by 03Z33 View Post
The offset is fine. I run the same tire size, but with the DF's the car will not sit low enough and you will have a big gap between the fender and the tire (almost like stock). You might consider 205/50/16 if you want the lowered look without the wheel gap.
I was considering 205/50/16s but I've read posts by another user (can't recall his username at the moment) running this size tire on the same size wheel with lowering springs and he said he's experienced slight rubbing. His offset is +40 I believe though. His car does look great with the setup but I'd rather not run the risk.
driver centric is offline   Reply With Quote
need 17inch rim guidence chino_potato Wheels, Tires and Suspension Forum sponsored by The Tire Rack 46 04-09-2007 12:09 PM
Max offset riceboy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 05-01-2006 09:57 PM
