#1 | |
![]() ![]() Drives: 07 Yaris 3 door Join Date: Feb 2013
If you don't like the slip joint, just put some tack welds on it once you get everything fitted and clamped, pull it down and weld it up. As for sliding the header on once the cross member and engine are in place, sounds like for others planning on doing this, it would be better to install the header onto the engine prior to installing the engine in the car. Last edited by beaker; 03-30-2016 at 06:21 AM. |
#2 | |
![]() ![]() ![]() Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR Join Date: Mar 2007
I will probably just end up welding the slip joint like you said. I would install the header before putting the engine in, or drop the crossmember. Honestly though, I would probably just cut that tab off. I will have to cut it off with an angle grinder if I want to get the header back out. I can always fab up another mount if I need to. I am not gonna bother with a mount bracket for now. |
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 02:58 PM |
| 1nzfe throttle body swap and fitment questions | EchoBob02 | Performance Modifications | 14 | 05-01-2014 08:02 AM |
| 60/40 to Bench Seat Swap Issue | CTScott | Cosmetic Modifications (Exterior/Interior) | 24 | 11-26-2012 02:45 PM |
| FS: COMPLETE 2ZZ SWAP!!!! (SOCAL) | AdeJong 03 | Items for Sale by private party | 4 | 04-05-2010 11:25 PM |
| Gauge Cluster Swap, other interior swap questions. | Adrenalingirl_K | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 04-09-2009 03:32 AM |
