Old 04-17-2016, 08:13 PM   #1
Gagi
Gagi's Avatar
Drives: Yaris 1.33 vvti 2015
Originally Posted by karloslatynos View Post
Finally I've managed to fit them.
reference:
http://www.yarisworld.com/forums/showthread.php?t=56223
just plug & play
As far as I know the French build Yaris is pre-wired for:
- front fogs
- cruise control
- footwell lights
- ...(what else is there to discover?)
I love toyota
Do you have glove box light equipped? If not, your model has that connector too.
Gagi is offline   Reply With Quote
Old 04-26-2016, 04:13 AM   #2
karloslatynos
karloslatynos's Avatar
Drives: 2012 Yaris TR 1.33 VVT-i Man
I don't have the glove box light equipped. I've tried to locate it and found 2 unused connectors (ref. the picture) I am not sure if any of them are glove box light connector. If anyone know the part number of the glove box light would be appreciated.
karloslatynos is offline   Reply With Quote
Old 04-26-2016, 02:15 PM   #3
Gagi
Gagi's Avatar
It is exactly the same part that goes for foot light. The connector is also the same. Since it's RHD I'm not sure where it should be hidden, but on LHD vehicles is taped on the cable connected to airbag-off switch. It is probably near all those cablings from your picture. Could you make another image of upper right corner of that inner part of dashboard? You will find that F103 connector (it should be black ) is glove box light (red and white wire).
InpaneL-TMMF-P3.pdf
Old 04-27-2016, 04:38 AM   #4
karloslatynos
Attachment 57058
I had a good look and discover mounting place for glove box light (pic. 1) I have used my footwell light for demonstration (however it didn't fit perfect so maybe the right one is slightly different. When ordered with the number parts it was only two in the bag) After a number of attempts I did not located any connector near the airbag-off connector.
The footwell light connectors were clearly visible, just hanging out. Unfortunately in my model there is nothing near the glove box light mounting
Old 04-27-2016, 05:14 AM   #5
Gagi
Gagi's Avatar
In the file attached in my previous reply you can see F84 junction connector and its possible location. And that location should be middle of the dashboard underneath windscreen.
In this drawing attached (this reply) on page 6 you can see junction connectors F84/F85. That would be black male/female plug in your car. From connector F85 red wire on position 21B should lead you to F103 connector for glove box light. If they left connectors for foot-light, there must be connector for glove box. Don't give up. I will check again, but in parts catalogue, same part number appears for that group of lights.
Illumination.pdf
LED tail lights installed Cutie Pie #2 Cosmetic Modifications (Exterior/Interior) 10 08-20-2012 11:25 PM
Yarisworld.com DIY Manual v3 vodkalush Downloads for Registered Members 30 01-21-2007 10:54 PM
DIY KEYLESS ENTRY on Power Liftback? TC-LIFTBACK DIY / Maintenance / Service 0 08-23-2006 09:57 AM
