Old 04-27-2016, 04:38 AM   #14
karloslatynos
karloslatynos's Avatar
Drives: 2012 Yaris TR 1.33 VVT-i Man
Originally Posted by Gagi View Post
It is exactly the same part that goes for foot light. The connector is also the same. Since it's RHD I'm not sure where it should be hidden, but on LHD vehicles is taped on the cable connected to airbag-off switch. It is probably near all those cablings from your picture. Could you make another image of upper right corner of that inner part of dashboard? You will find that F103 connector (it should be black ) is glove box light (red and white wire).
Attachment 57058
I had a good look and discover mounting place for glove box light (pic. 1) I have used my footwell light for demonstration (however it didn't fit perfect so maybe the right one is slightly different. When ordered with the number parts it was only two in the bag) After a number of attempts I did not located any connector near the airbag-off connector.
The footwell light connectors were clearly visible, just hanging out. Unfortunately in my model there is nothing near the glove box light mounting
karloslatynos is offline   Reply With Quote
LED tail lights installed Cutie Pie #2 Cosmetic Modifications (Exterior/Interior) 10 08-20-2012 11:25 PM
Yarisworld.com DIY Manual v3 vodkalush Downloads for Registered Members 30 01-21-2007 10:54 PM
DIY KEYLESS ENTRY on Power Liftback? TC-LIFTBACK DIY / Maintenance / Service 0 08-23-2006 09:57 AM
