Old 05-05-2016, 08:10 PM   #1
Javier_vios
Drives: Toyota Vios Yaris
Hello,
I see that cruise control is not even an optional in Vios/Yaris, but the steering wheel came with a cover to remove for a cruise control switch, that`s why I belived that is was posible conecting the ecm in the correct pin...
If is not posibile just conecting the switch to ecm, Is another solution ?? A toyota module ??? An after market cruise control ?? Another ecm ??
Thank you both for your answers... by the way this yaris is made in Thailand.
Best Regards
Javier
Javier_vios is offline   Reply With Quote
Old 05-06-2016, 08:21 PM   #2
Originally Posted by Javier_vios View Post
Hello,
Best Regards
Javier
Toyota uses many of the same parts on cars, even if the feature is not present. Also, that cover is the only way to access the release tab for the airbag on that side of the steering wheel.
Old 05-07-2016, 12:15 AM   #3
jcboy
Drives: Sedan 07
Hello,
Best Regards
Javier
I've been dreaming and been envious of the Cruise Control discussion in this forum for a while now. Very useful especially when using Superhighways, where the stretch is at least 75km long but top speed is limited to 100km/h.
Cool, some of my Yaris parts are made in Thailand actually, i've seen Made in Japan too in some them (IIRC).
This is our steering wheel and if this is the same, then Scott is correct, it's only an access door for the release tabs. (to remove SW)
Old 06-11-2016, 08:49 PM   #4
Javier_vios
Hello,
This is my toyota steering wheel, I`m still hoping solution, I know that this ECM is not the one that have cruise control in pin 40 of conector 21, but the ECM of 4 row and 4 conector could have cruise control programing in pin 21 of the conector with 31 pins as in toyota hilux ...
Any comments ??
Best regards
Javier
Yaris cruise control doesn't work pootango DIY / Maintenance / Service 10 07-02-2012 04:11 PM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
