Old 05-07-2016, 04:10 PM   #1
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
Originally Posted by BennyLava View Post
My rotors on my 2009 Yaris sedan have finally worn out. They have that "rotor shimmy" that tells you its time to either replace the rotors, or have them shaved. I'm kind of on the fence about having them shaved. They're going to lose thickness, which technically makes them out of spec with what toyota intended. So I'm not sure I'm really for "turning" rotors, as some people call it. Others call it shaving them. My local orielly's or autozone will turn them, but I'm thinking a brake upgrade is in order. So here's my questions:
1. So what is a good brake rotor upgrade, that won't break the bank? Perhaps those EBC slotted rotors that come in black? I don't think I really want drilled rotors, as they do have a tendency to crack. But which rotors would last a long time, and definitely be an upgrade to stock rotors?
2. I'd also like to do some braided stainless steel brake lines. If I'm right about this (and I could be wrong) my Yaris should have rubber brake lines that actually connect to the caliper itself. Same thing that is on my old 1987 Silverado. Well, as I'm sure you all know, if you replace those with braided stainless steel upgrades, those lines can no longer "bulge" or flex, from the inside out. Which is why they make the braided steel ones. And thus, your braking is slightly improved. Does anyone make such a thing for the yaris? And if so, which ones would you recommend? I'm probably going to go ahead and change the brake fluid, since it just hit 150k miles on the odometer. Might as well switch over to stainless steel lines if I'm going to have to change the brake fluid.
3. Pads? Is there a pad upgrade, to the stock toyota pads that my car has? When I got the car, it only had 40k miles on it. So I'm sure it still had the stock pads and rotors still on there. But now since I'll be replacing the rotors, I'm going to replace the pads too. Is there an upgraded pad, that will actually perform any better, perhaps last just as long, and maybe not produce much brake dust? I have my doubts that there is actually a better pad, than the stock toyota pads, for the yaris. But I just thought I'd ask.
Anyway, thanks for reading!
EDIT: I'm thinking maybe something like this for the pads and rotors. Any reason I shouldn't go this route? Not sure about the pads...
http://www.ebay.com/itm/EBC-Brakes-S...dXKfV5&vxp=mtr
#1. I would personally stay away from drilled rotors, and I would say "maybe" towards the slotted. They look cool, but i don't believe they perform as well as regular rotors because there is a lower contact area between the pad and rotor. The slots are believed to extend pad life, however I personally would trade longer life for better stopping power. That's really all your call though.
#2. Definitely one of the best times to upgrade! Plenty of manufacturers to choose from. You can't go wrong with either of them.
http://www.proimporttuners.com/parts...-line-kit.html
http://www.frsport.com/GOODRIDGE-210...S_p_12298.html
http://www.ebay.com/itm/Toyota-Yaris...MAAOSw~gRVlGjJ (personally have and use this set, one of the best braking upgrades I've made!)
#3. In terms of pads, I would suggest looking for some that offer good brake fade and low dust characteristics. Carbotech have some of the best fade resistance pads with a low dust formula. (http://www.ebay.com/itm/Carbotech-CT...EAAOSwll1Wu7hA)
Many people on this forum also run Hawk Performance pads on their cars for the same reason. (http://hawkbrakesdirect.com/p-377-hp...rake-pads.aspx)
Hope all this info helps!
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog
invader166 is offline   Reply With Quote
Old 05-07-2016, 05:33 PM   #2
BennyLava
Drives: 1987 Silverado
I ll be 60 this year and have fixed my own cars since I was 17 for myself, family and friends.
The only car I ever came across the manufacturer said DO NOT resurface rotor is MB.
IVE NEVER HAD A problem doing it.
I've seen em crack, twice. One was a friend in high school on his old chevy, the other on my grandfather's lincoln. BOTH after having them turned. Thats what makes me question it
Thanks for the help! But I wonder why the first set of braided lines is half the price of the other two. Half the quality? lol
BennyLava is offline   Reply With Quote
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
brake and rotors the_boss Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 03-23-2011 09:18 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
BIG(GER)TM BRAKE KIT Vanderkitten Performance Modifications 23 01-04-2009 07:16 PM
