![]() ![]() ![]() Drives: 1987 Silverado Join Date: Jan 2010
Time to replace rotors. Which brake upgrades?
My rotors on my 2009 Yaris sedan have finally worn out. They have that "rotor shimmy" that tells you its time to either replace the rotors, or have them shaved. I'm kind of on the fence about having them shaved. They're going to lose thickness, which technically makes them out of spec with what toyota intended. So I'm not sure I'm really for "turning" rotors, as some people call it. Others call it shaving them. My local orielly's or autozone will turn them, but I'm thinking a brake upgrade is in order. So here's my questions:
1. So what is a good brake rotor upgrade, that won't break the bank? Perhaps those EBC slotted rotors that come in black? I don't think I really want drilled rotors, as they do have a tendency to crack. But which rotors would last a long time, and definitely be an upgrade to stock rotors? 2. I'd also like to do some braided stainless steel brake lines. If I'm right about this (and I could be wrong) my Yaris should have rubber brake lines that actually connect to the caliper itself. Same thing that is on my old 1987 Silverado. Well, as I'm sure you all know, if you replace those with braided stainless steel upgrades, those lines can no longer "bulge" or flex, from the inside out. Which is why they make the braided steel ones. And thus, your braking is slightly improved. Does anyone make such a thing for the yaris? And if so, which ones would you recommend? I'm probably going to go ahead and change the brake fluid, since it just hit 150k miles on the odometer. Might as well switch over to stainless steel lines if I'm going to have to change the brake fluid. 3. Pads? Is there a pad upgrade, to the stock toyota pads that my car has? When I got the car, it only had 40k miles on it. So I'm sure it still had the stock pads and rotors still on there. But now since I'll be replacing the rotors, I'm going to replace the pads too. Is there an upgraded pad, that will actually perform any better, perhaps last just as long, and maybe not produce much brake dust? I have my doubts that there is actually a better pad, than the stock toyota pads, for the yaris. But I just thought I'd ask. Anyway, thanks for reading! EDIT: I'm thinking maybe something like this for the pads and rotors. Any reason I shouldn't go this route? Not sure about the pads... http://www.ebay.com/itm/EBC-Brakes-S...dXKfV5&vxp=mtr |
First of all, most rotors have specs for how much material can be removed to refurbish them. So turning them doesn't necessarily put them "out of spec".
Necessarily? So do you know whether or not it would?
I ll be 60 this year and have fixed my own cars since I was 17 for myself, family and friends.
The only car I ever came across the manufacturer said DO NOT resurface rotor is MB. IVE NEVER HAD A problem doing it.
#5 | |
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
#2. Definitely one of the best times to upgrade! Plenty of manufacturers to choose from. You can't go wrong with either of them. http://www.proimporttuners.com/parts...-line-kit.html http://www.frsport.com/GOODRIDGE-210...S_p_12298.html http://www.ebay.com/itm/Toyota-Yaris...MAAOSw~gRVlGjJ (personally have and use this set, one of the best braking upgrades I've made!) #3. In terms of pads, I would suggest looking for some that offer good brake fade and low dust characteristics. Carbotech have some of the best fade resistance pads with a low dust formula. (http://www.ebay.com/itm/Carbotech-CT...EAAOSwll1Wu7hA) Many people on this forum also run Hawk Performance pads on their cars for the same reason. (http://hawkbrakesdirect.com/p-377-hp...rake-pads.aspx) Hope all this info helps!
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
#6 | ||
I guess if I saw one crack I'd feel the same.
I can't say for sure that both those rotors weren't chinese junk, that got put on the vehicles at some point along the way. But it gave me pause. I would like to know the rest of the details. Like how thin a rotor can really be before it cracks, what effect a thinner rotor has on braking (if any) etc
Its very rare that i wear out a set of brakes because i drive so I seldom make much use of them. Ive ridden motorcycles for decades and never had issues with the discs and discs on a mc are MUCH thinner than auto discs. O fcourse mc s are 1/4 the weight of cars...
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
Drilled rotors = NO
Slotted = NO On the track no one uses them!!!! Plenty of information on rotors if you google. |
I'd have the rotor turned, the oem ones are made from better materials then the cheap rotors all the parts houses sell.
I heard that the braided hoses should be replaced often too. |
This is also a concern for me. However those EBC ones I linked, probably exceed the OEM quality. That's just a guess though, but EBC is known for high quality on their expensive rotors. They do have less expensive offerings though. I'm going to call the toyota dealer and get a price on OEM ones.
Does anyone happen to know the brand (if its not just "Toyota brand") that toyota uses for rotors on the 09 yaris? Or perhaps a part number? Its the sedan, if that matters.
#14 |
![]() ![]() Drives: NONE Join Date: Oct 2008
I used Wagner Brake BD126409 ThermoQuiet Disc Brake Rotors a couple of years ago when I serviced my brakes. They are OE qaulity
http://www.opticatonline.com/part/wa...sc-brake-rotor For pads I used Wagner Brake ZD1184 Quick Stop Disc Brake Pads http://www.opticatonline.com/part/wa...disc-brake-pad |
#15 | |
#16 |
![]() ![]() Drives: 2007 Toyota Yaris LB Join Date: Mar 2007
Centric Premium Rotors with Centric POSIQUIET pads is a good combination. Many people reported that they had good experience with Centric rotors and pads.
#17 | |
![]() ![]() Drives: 2013 Hatchback Join Date: Dec 2012
#18 |
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| Get your post counts here! *read 1st post for rules* | Astroman | Off-topic / Other Cars / Everything else Discussions | 3414 | 11-04-2012 09:03 AM |
| brake and rotors | the_boss | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 03-23-2011 09:18 PM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
| BIG(GER)TM BRAKE KIT | Vanderkitten | Performance Modifications | 23 | 01-04-2009 07:16 PM |
