Old 05-09-2016, 05:08 AM   #1
cyberguy
Drives: d4d
Originally Posted by rabbito View Post
i was running horrible Bridgestone tires 185/60/15 that came on my stock TRD rims (15x5)...after i did some performance modification i changed my tires to Hankook V2 195/50/15 which is pretty good..i have dropped about 1 inch due to shorter tire wall..i am not stil confident through corners on high speed 100km+ (maybe im pissed because i lost to BMW 5 series during corners)...what is the issue? i have front tower strut and rear sway with performance strut and shock all the way around droped 1.5 inch..
do i need a wider width rims..?
or better tires?
Sent from my ASUS_Z00AD using Tapatalk
are you sure that your rims are 15x5? if yes then 195 is too wide for your rim. I use toyo r1r 195/50/15 with a 15x7 rim and they are ideal for my car. Also I am much faster in turns than with the stock 185/60/15
cyberguy is offline   Reply With Quote
Old 05-09-2016, 05:14 AM   #2
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
sorry dude, its 15 x 5.5...actually 195 is the widest fit (check the tire chart) for 5.5..185/60/15 is from the factory...
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Tire rotation question vasonline Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 02-15-2016 10:42 AM
Costco Tire Damage Issue nkaufman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 03-16-2015 06:48 PM
Tire Size and FE question GMKing Fuel Economy Forum 8 09-01-2009 09:20 PM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
