Originally Posted by NYC-SE
Good to know that the 2015+ SE models do NOT have the rear axle back beam dynamic dampers. I wasn't sure about that Kalispel, I mentioned that I was only sure about the 2012-2014 SE models. Sorry to make you spend money on bolts that you didn't need.
Glad to hear you were able to install with no problems. It's a great mod, as you have discovered.
We had a rough time getting the two primary bolts loosened, so that we could install the sway bar in the occupied bolt-holes. We had to jack up the rear end and take off the rear wheels to get the space/angles needed to loosen up those suckers. Luckily, my nephew has a lot of do-it-yourself tools and heavy-duty jacks (he does a lot of work/mods on his 1999 Lexus sports-coupe). I would rather have the extra bolts and not need them, than need those variant-thread bolts and not have them.
Plus, with my luck, my SE should have had those dampeners installed, but didn't due to some factory-assembly oversight. I won't know until someone else here with a 2015/2016 SE crawls up under their car and takes a look to confirm.
