Old 05-10-2016, 07:20 PM   #1
You keep saying the radiator is busted, when all we can see is a damaged overflow reservoir. Is the radiator itself indeed damaged and being replaced, or just the reservoir?
Old 05-10-2016, 07:23 PM   #2
Midwesterner
Drives: 2009 Yaris Hatchback
Yes. As described earlier, when I poured water into the big tube, it came out of the radiator as fast as I could pour. Apparently there are 2 grommets and plastic pieces on the bottom that busted off as well as the hole in the overflow tank.
Sent from my SM-N900R4 using Tapatalk
Midwesterner is offline   Reply With Quote
Tags
radiator
Radiator Fan not working.. Beubeu DIY / Maintenance / Service 3 09-21-2015 12:53 PM
2007 Yaris Radiator Fan kcanaj Yaris TS Talk 1 07-25-2015 09:13 PM
radiator small leak esse10 DIY / Maintenance / Service 2 08-20-2013 11:40 AM
Radiator Change TMR3 DIY / Maintenance / Service 5 06-22-2012 12:11 PM
Radiator hose size window_lee General Yaris / Vitz Discussion 0 03-31-2009 06:33 AM
