Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 07-25-2015, 12:42 PM   #1
kcanaj
Drives: 2007 yaris sedan
2007 Yaris Radiator Fan
I have a 2007 Yaris and the problem is when turning AC on radiator fan does not run, same thing I tried turning the heat on and the engine changes the sound, running harder but the radiator fan is not running. I checked the Relay is good, tried connecting fan directly is good. Pulled two connections from engine one is on top and one lower I don't know which one is for fan or What else should I check?
If anyone can help?
kcanaj is offline   Reply With Quote
Old 07-25-2015, 09:13 PM   #2
The FAN NO1 Relay drives the fan by command of the ECM. The 30A RDI fuse feeds it power.
2007 and up Yaris Sedan S McDizzle New YARIS Purchase Forum 3 12-03-2009 01:42 PM
