Old 05-13-2016, 10:40 PM   #1
Cigar_Maverick
Cigar_Maverick's Avatar
Drives: 2007 Yaris Hatchback
Took the car out and warmed up the pipes on the 2007 Yaris. Got the O2 Sensor and Air/Fuel sensors removed pretty easily. Bought DENSO sensors from Rock Auto. The O2 sensor in PN 234-4069. The O2 sensor looks a LITTLE different. Just want to be sure I'm ok to install it in the morning. See the picture below of the old/new O2 sensor:
On an unrelated note, when I took the console out, I saw these unused wires. This car does not have a lot of options, so I was just wondering what these would have been for. Power lock/windows?? see below:
Also, I assume I use all of the lube on the threads that came with each sensor? Can't use TOO much can ya?
THANKS!
Russ
Cigar_Maverick is offline   Reply With Quote
Old 10-06-2016, 01:37 AM   #2
07liftback
07liftback's Avatar
Drives: 07 Yaris Liftback
Looks like it's for the power locks. My Yaris came with power locks and the master switch is right next to the hand brake and shifter.
I just did my oxygen sensor and although it seemed impossible to reach from the top at first, it was MUCH easier getting at it from the front rather than crawling under the car. The only reason I got under the Yaris was to spray the PB blaster on it since I couldn't see what I was spraying when hovering above it.
Using a 3/8" drive ratchet and a oxygen sensor socket, I wasn't able to get leverage either above the car or below it so I had to attach a "cheater pipe" on the handle. It's basically a metal pipe from an old bedframe that I place over the ratchet and was able to get superb leverage without kicking or hammering the ratchet. I could probably use this cheater pipe without the PB blaster prep and still do okay.
Anywho, does anyone know if it's absolutely necessary to reset the ecu by unplugging the battery or will the car relearn the readings from the new oxygen sensor? I will continue without resetting the ECU to see when my MPG will finally improve.
07liftback is offline   Reply With Quote
Old 10-06-2016, 03:39 PM   #3
Cigar_Maverick
Honestly, I'm trying to remember if I unhooked the battery or, more likely, went to the local parts store and had them clear the errors. Almost certain I just had the codes cleared. No errors since.
Old 10-07-2016, 02:31 AM   #4
07liftback
07liftback's Avatar
Did mpg improve right away?
Old 10-07-2016, 09:21 AM   #5
Cigar_Maverick
Unfortunately, that is hard to say... The weekend I put the new one in, I also switched to Mobil 1 synthetic Advanced Fuel Economy, put a new air filter in and new plugs. I had just bought the car and didn't know the maintenance history. The total gained me 2.5 MPG. Going from 37.5 to 40. I am led to believe that, in my situation, the new sensor has minimal effect. That having been said, as they say, your results may vary. In hindsight I might have done a more controlled experiment, but I just hammered it all out at once. Maybe somebody else can chime in who has more experience with just installing the new sensor.
Our 07 Yaris Hatch! Saity Photo-Video-Media Gallery 2 12-12-2009 07:48 PM
First Texas Yaris Yak (Lots of pics :) Slick Photo-Video-Media Gallery 38 10-02-2009 12:25 PM
