#37 | |
![]() ![]() Drives: 07 Yaris Liftback Join Date: Nov 2010
I just did my oxygen sensor and although it seemed impossible to reach from the top at first, it was MUCH easier getting at it from the front rather than crawling under the car. The only reason I got under the Yaris was to spray the PB blaster on it since I couldn't see what I was spraying when hovering above it. Using a 3/8" drive ratchet and a oxygen sensor socket, I wasn't able to get leverage either above the car or below it so I had to attach a "cheater pipe" on the handle. It's basically a metal pipe from an old bedframe that I place over the ratchet and was able to get superb leverage without kicking or hammering the ratchet. I could probably use this cheater pipe without the PB blaster prep and still do okay. Anywho, does anyone know if it's absolutely necessary to reset the ecu by unplugging the battery or will the car relearn the readings from the new oxygen sensor? I will continue without resetting the ECU to see when my MPG will finally improve. |
#38 |
![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Mar 2016
Honestly, I'm trying to remember if I unhooked the battery or, more likely, went to the local parts store and had them clear the errors. Almost certain I just had the codes cleared. No errors since.
#39 |
#40 |
Unfortunately, that is hard to say... The weekend I put the new one in, I also switched to Mobil 1 synthetic Advanced Fuel Economy, put a new air filter in and new plugs. I had just bought the car and didn't know the maintenance history. The total gained me 2.5 MPG. Going from 37.5 to 40. I am led to believe that, in my situation, the new sensor has minimal effect. That having been said, as they say, your results may vary. In hindsight I might have done a more controlled experiment, but I just hammered it all out at once. Maybe somebody else can chime in who has more experience with just installing the new sensor.
#41 |
Any gas mileage improvement found after replacing one or both sensors???
#42 | |
That's why the first oxygen sensor is often referred to as the air fuel ratio sensor. |
#43 |
![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
Hey all..
I decided to check out my Air/Fuel sensor and based on the service manual inspection page(EC-18) From terminals 1>>2 it should read approx. 1.8 to 3.4ohms, mine read 2.8 ohms, but when I check terminals 1>>4 it should read approx. 10K or > ohms, but I read open.. No reading.. I am not throwing any engine code, so its seems odd to me.. Does anyone have a spare sensor they are also measure and see what you get on the 1>>4 terminals?.. I get about 490KM on approx. 38 liters of gas.. I drive pretty hard , and that's about 7.7L per 100KM.. which seems OK... Any thoughts ? Thanks guys! |
#44 | |
Anyone ?
#45 |
![]() Drives: 2008 Yaris S Hatchback Join Date: Oct 2017
Darn, I got the p0031 error code as well after I replaced my donut gasket.
Did anyone confirm which sensor as corresponded to this code? |
#46 |
Drives: 2012 Toyota Yaris Join Date: Nov 2017
I have a 2012 Toyota Yaris 5-door and could not for the life of me find the location of the downstream O2 (Bank 1/Sensor 2) wire harness. Remove the center console and pull back the tab of carpeting in the front. The "plug" is located right there (see pic). The harness comes exits the body of the car on the side of the metal that the plug part is mounted on. Hope this saves someone time....
#47 | |
Drives: '12 Yaris SE Join Date: Nov 2011
#48 |
![]() Drives: 07 Yaris Join Date: Jun 2020
#49 |
![]() Drives: 2007 yaris hatch back Join Date: Jun 2020
I think I'll remove mine, clean it with a wire brush, and reinsert it
#50 |
Just sharing my experience - recently I received error P0420 which indicates deteriorated catalytic converter. The light came back a few days after I erased the code. 2007 car with 172tkm (107t miles). I decided to change the O2 sensors as I learnt that they should be preventively changed in 160 tkm due to their laziness they build over time.
After the change the error is gone and the car is considerably more agile. Both Denso direct fit sensors together cost some 130 USD here. The upper one went out quickly while the one down the cat was a bit harder. Still - I used the WD40, a special nut, ratchet and a piece of pipe and it went off, even from a cold exhaust pipe. I was getting ready for some serious battle (even bought a torch for this) but in the end it was not necessary. Yay! Btw I do not think that cleaning it with a wire brush is a good idea. The sensor is inside a metal cap, you can never reach it with the brush. And even if you do - you will destroy it. |
#51 |
![]() Drives: Yaris 1.3 Terra Mk2 2006 Join Date: Dec 2015
i recently changed my 2006 Mk2 Yaris 13. Terra (120.000km) upper side oxygen sensor.
The engine light was on for the last 5 years and checked with the service, confirming it was faulty oxygen sensor. Toyota dealer asked around $300 for the change. Then after tons of research i bought a matching Denso sensor (DOX0109) that was similar to the original one without the socket. It had bare wires and connectors inside. You need to cut the existing socket and swap it on to the new one. Even the wire colors are the same. I put it and yes, it works perfectly. It all cost around $45 Now the fuel consumption is as good as new. Like 1-2 litre/100km difference with the new one. So take it as a spare if you find. You'll need it. Also the car had emission problems, i hope it's also fixed. I'll see in the next inspection. |
| Our 07 Yaris Hatch! | Saity | Photo-Video-Media Gallery | 2 | 12-12-2009 07:48 PM |
| First Texas Yaris Yak (Lots of pics :) | Slick | Photo-Video-Media Gallery | 38 | 10-02-2009 12:25 PM |
