Old 12-31-2016, 01:01 PM   #1
chuckiek1
Drives: 06 Yaris
Torque setting for brake job
Thought this should be included here:
Caliper: 25 lb-ft, or 34 Nm
Caliper bracket: 79 lb-ft, or 107 Nm
Tyre lugs: 76 lb-ft, or 103 Nm
chuckiek1 is offline   Reply With Quote
Old 04-28-2018, 12:13 PM   #2
Runethecursed
Drives: 2009 Yaris S
Bump from the Graveyard but for any of you lurkers, You'd want to get the brake caliper from a 0-14 Scion XD OR 9-13 Corolla LE,STD model
If you are like me and hit up junkyards more often than you call your mum... itll be useful info
Runethecursed is offline   Reply With Quote
Old 10-22-2018, 03:01 PM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Just finished installing this setup on my car. It's actually the stuff in the pictures--bought them off Brushforhire after he totaled his. Install is super simple, barring any problems with stuck/rusted bolts. Still have to bleed the lines and refresh the brake fluid, but really looking forward to these!
Old 10-23-2018, 01:38 AM   #4
Runethecursed
Tell me how they feel, I put the bigger calipers on and while my booster might have been failing I hated the mooshy feel.
Old 03-28-2019, 02:29 PM   #5
CrankyOldMan
Looks like I missed the notification on this one. I've probably got some air in the hydraulics still, they didn't really firm up even after bleeding them twice. It's currently down for a slipping clutch, hopefully not related.
Old 03-28-2019, 12:42 PM   #6
firebird1999us
firebird1999us's Avatar
Drives: 2003 Mach 1
Sorry to bump an old thread - but will this work on a 2009 Yaris hatch with 15" wheels? I started compiling the parts and several OEM parts sites listed the rotors as fitting 2012 and on Yaris. I'm assuming they will but just need confirmation! My brakes are shot and I was considering this option vs slotted stoptech rotors from tire rack...
firebird1999us is offline   Reply With Quote
Old 03-28-2019, 02:27 PM   #7
CrankyOldMan
Shouldn't be a problem. I run Mini Cooper 15" alloys and they just clear.
Old 03-28-2019, 02:36 PM   #8
tmontague
tmontague's Avatar
I have a feeling the mushy feeling has to do with runnigmarger calipers without upgrading the rest of the system. The pedal feel would be very sensitive to changes in fluid volume and likely leading to more pedal throw being needed (read: mushy feeling)
They tried something like this on the micra cup cars in the rear and found it threw everything off if the rest of the system wasn't properly matched
Old 06-25-2019, 11:13 AM   #9
CrankyOldMan
Posting an update for posterity!
I ran some OEM-grade pads with these on the road and they were acceptable. Tried them at the track and the pads were unable to deal with the heat. Changed over to Hawk HPS pads (HB627F.690), bled the lines and bedded in the pads. Phenomenal difference in stopping power and braking confidence! The pedal still has a lot of travel before it starts to engage but that may be related to the difference in brake boosters between the xD and the Yaris.
Old 06-02-2020, 07:46 PM   #10
v114
Drives: 2006 yaris d-4d
Made the upgrade today, french version (original calipers are a bit different) with parts with the oem reported by OP, no problems at all installing the parts
60€ subaru trezia calipers
70€ brembo coated rotors
40€ ferodo ecofriction pads
15€ paint
No spongy feeling, no slack on the pedal, nice extra stopping power
Thank you very much for this post!
v114 is offline   Reply With Quote
Old 12-11-2020, 06:28 AM   #11
jng
Drives: 1NZFE NCP93 (Vios)
Came across this thread and went for it!
And so... I managed to fit the calipers of Gen 11 Corolla (We call it the 2014 Altis in Asia) into my Yaris Sedan (Vios NCP93). Paired it up with a 4x100 275mm slotted rotor meant for Vios NCP93 "G" Model.
Follow me on Instagram - @Yarisedan
jng is offline   Reply With Quote
Old 01-19-2021, 08:38 PM   #12
NvrDwn
Drives: 08 yaris sedan 5spd
After upgrading my pads with hps 5.0 and new stop tech plain rotors and running multiple 80+ to 25 mph consecutively, I can't understand why you would want more unless you track it.
NvrDwn is offline   Reply With Quote
Old 07-30-2021, 02:03 PM   #13
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Add another one to list doing this upgrade.
I found the corolla calipers at pull-a-part. I ordered the SE rotors and Hawk pads from Amazon.....
Old 08-01-2021, 06:39 PM   #14
enviri
enviri's Avatar
Drives: 2010 Yaris
brings a tear to my eye...
Old 08-02-2021, 12:41 PM   #15
Flipper_1938
Very happy with the results. ...and yes, 15 steelies will fit.
Old 08-25-2021, 02:26 PM   #16
DevilzMafia
Drives: Toyota Yaris 2007
Thanks, was just gonna ask that.
Wondering if anyone tried the Yaris 2012 Calipers?
DevilzMafia is offline   Reply With Quote
Old 10-04-2021, 10:10 AM   #17
Rundstedt
Drives: Yaris III 2012
Hi guys!
I also want to upgrade front brakes on my Yaris 3rd gen 1.33, 2012 production year.
1st post of @brushforhire is great!
Sadly I can't find calipers with mounting brackets (or if I find one, I'm not really sure whether it is the correct part).
Does anyone have the part number for it?
Also, do I need to upgrade my heat shield? From what I measured larger rotors should easily fit, but maybe some does have a different experience.
Rundstedt is offline   Reply With Quote
Old 04-07-2022, 07:07 AM   #18
Calrenman
Drives: 2015 Toyota Yaris LE Hatchie
Great educational thread...BUMP!
Calrenman is offline   Reply With Quote
Time to replace rotors. Which brake upgrades? BennyLava DIY / Maintenance / Service 25 05-16-2016 05:57 PM
Problem removing front brake rotor jkuchta DIY / Maintenance / Service 24 02-27-2016 09:41 PM
Bolt Thread Size 4 Brake Drum Removal BobTheYaris DIY / Maintenance / Service 5 08-17-2014 01:14 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 08:14 PM
