Old 08-12-2014, 08:59 AM   #1
BobTheYaris
BobTheYaris's Avatar
Drives: '08 Yaris HB 2 dr
Bolt Thread Size 4 Brake Drum Removal
Does anyone know the bolt size need to back off the rear brake drums. Hafta check 'em for inspection and they aren't budging with hammering.
BobTheYaris is offline   Reply With Quote
Old 08-12-2014, 09:42 AM   #2
10mm x 1.5
Old 08-12-2014, 06:13 PM   #3
Antara
Drives: 08 Yaris HB
I use one of the bolts from the hood support.
Antara is offline   Reply With Quote
Old 08-13-2014, 08:42 PM   #4
BobTheYaris
thanks, hafta try the hood support bolt.
Old 08-14-2014, 02:28 PM   #5
instantninja
Drives: 07 yaris rs
if you have access to an air chisel try that with the bit I use for pushing bolts through leaf spring ends. go around the hub until it changes sound and it should come off
instantninja is offline   Reply With Quote
Old 08-17-2014, 01:14 PM   #6
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
BtY,
please keep us posted. I may need to do drum service too. Are you replacing anything, or just cleaning, adjusting, and bearing repacking?
jack black is offline   Reply With Quote
Shift lever thread size Chaad32 Cosmetic Modifications (Exterior/Interior) 16 01-30-2015 02:16 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
Shifter thread size kargoboy Cosmetic Modifications (Exterior/Interior) 7 12-18-2008 11:06 AM
Transmission Drian Bolt washer size CB900F2 DIY / Maintenance / Service 14 12-07-2008 07:03 AM
Exhaust Pipe Size (Tamaņo del tubo de escape) carlosh Central and South America 11 08-02-2007 04:15 PM
